03-17-2018, 11:06 | #1 (permalink) |
Insane Poster Join Date: Oct 2012 Location: Harare,Zimbabwe
Member: 1825426 Status: Offline Sonork: 100.1626329 Thanks Meter: 9 | G890A unlock failed New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. Operation: Read Codes DIAG Selected model: SM-G890A Software version: 31.0 Checking hash file... OK Searching Samsung modem... detected COM100 Reading phone info... OK Model: SM-G890A AP version: G890AUCU5CPK3 CSC version: G890AATT5CPK3 CP version: G890AUCS7DRA2 Product code: SM2G890AZAAATT Phone SN: R38G80XJDKK Unique number: 06157DF68B49C00D Searching Samsung diag port... detected COM270 Reading phone info... OK CP version: G890AUCS7DRA2 CP build: Jan 8 2018 14:08:58 Reading data from phone... error (1) Done with Samsung Tool PRO v.31.0 Any solutions |
