08-05-2016, 18:08 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Ortahisar
Member: 1929052 Status: Offline Thanks Meter: 22 | g901 f unlock ok but still lock UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G901F Selected port: COM132 SAMSUNG Mobile USB Serial Port Software version: 26.3 Reading phone info... Reading IMEI... OK IMEI: 3************** Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.3 |
08-10-2016, 10:19 | #3 (permalink) |
Freak Poster Join Date: Mar 2001 Location: EU
Member: 3847 Status: Offline Thanks Meter: 6 | Same problem: Reading phone info... Reading IMEI... OK IMEI: 355******** Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.3.1 Unlock done, but phone not unlocked. G901F 6.0.1 version |
The Following User Says Thank You to Bemsas For This Useful Post: |
08-10-2016, 15:16 | #6 (permalink) |
Freak Poster Join Date: Jan 2015 Location: GSM Net Age: 46
Member: 2334036 Status: Offline Thanks Meter: 131 | try this modem, it is from android 5 for G901F https://www.androidfilehost.com/?fid=24052804347810377 |
The Following User Says Thank You to mach6 For This Useful Post: |
09-16-2017, 14:29 | #10 (permalink) |
Insane Poster Join Date: Apr 2015 Location: VBVBHVB
Member: 2383066 Status: Offline Sonork: VNBV Thanks Meter: 85 | SM-G901F 6.0.1 unlock without full flashing 1. flash in Odin3_v3.11.1 put the file in cp modem then flash you got no imei... 2. unlock the phone with octopus or z3x without root... 3.flash again the 2nd file then you have imei now... Modem unlock G901F 6.0.1.rar - 48.0 MB |
