08-04-2017, 08:01 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2521399 Status: Offline Thanks Meter: 2 | G920R4 Cant Write Cert I can downgrade it to the operating system before it, android 6, but the problem is the same. When i try to write cert: Operation: Write CERT Selected model: SM-G920R4 Selected port: COM271 SAMSUNG Mobile USB Serial Port Software version: 29.0 Checking CERT file... OK KEY ID: 0053 Waiting ADB device... OK Reading phone info... Model: SM-G920R4 Android version: 6.0.1 Product code: Not Active Phone version: G920R4TYS4CPL1 PDA version: G920R4TYS4CPL1 CSC version: G920R4USC4CPL1 CSC country code: USA CSC sales code: USC HW version: G920R4.02 Phone SN: Modem board: MDM9635M Security patch: 2016-12-01 RF cal date: 2015.10.23 IMEI: Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.29.0 When i try to reset msl: Operation: Reset MSL Selected model: SM-G920R4 Selected port: COM271 SAMSUNG Mobile USB Serial Port Software version: 29.0 Reading phone info... Reading IMEI... OK IMEI: 990005848635034 Reseting MSL security... error (0) Done with Samsung Tool PRO v.29.0 I tried downgrading the modem, which it will let me do, but it still does not want to allow me to reset the msl. Any way that i can write cert to this phone or am i out of luck? |
08-04-2017, 19:17 | #2 (permalink) |
Member: 2521399 Status: Offline Thanks Meter: 2 | Follow up: I flashed this: COMBINATION_USC_FA50_G920R4TYU4APK1_USC4APK1_CL499 2770_QB11463896_REV02_user_mid_noship.tar It lets me write the cert, but the phone now has an MEID of 99000584863503 (that is not the imei of the cert, nor the original) When i flash back to stock firmware, the MEID stays like this, but the IMEI shows the original imei of the phone. In *#0011* it shows IMEI CERTI: FAIL, -9 I still cant reset the MSL or reset the EFS. It throws off errors. The cert files use the same key as this model, so it should not be a big problem. Any ideas on how I can manually reset fix this? Perhaps manually reset the efs? Is there anything z3x can do to help? I can install teamviewer if necessary. |
08-04-2017, 19:40 | #3 (permalink) |
Freak Poster Join Date: Jul 2013 Location: sialkot
Member: 1972648 Status: Offline Thanks Meter: 45 | the samsung after 2016 and 2017 rest efs 99% time work for me flash back to stock firmware rest efs need BST dongle for rest efs and will back with orgnal imei |
08-04-2017, 22:17 | #4 (permalink) |
Member: 2521399 Status: Offline Thanks Meter: 2 | Not too keen on spending a bunch of money to fix one problem. Would be cheaper to replace the motherboard. Is it for certain the BST works on the newest firmwares for the s6? Also, still hoping Z3X team can help me fix/repair the EFS for this phone. When i write the QCN backup i made it says restoring EFS but it doesnt touch it. |
08-04-2017, 23:49 | #5 (permalink) |
Member: 2521399 Status: Offline Thanks Meter: 2 | Managed to reset the EFS, but now the IMEI is B0000000 IMEI CERTI: FAIL, -3 When i write cert, it changes only the IMEI CERTI: FAIL, -7 The IMEI stays the same though. B0000000 Any help you can provide Z3X?? |
