![]() | #1 (permalink) |
Junior Member ![]() Join Date: Mar 2016
Member: 2549245 Status: Offline Thanks Meter: 2 | G925F error after flash combination Before flash combination I flashed full service firmware G925FXXU4DPJN. ![]() |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Generally no problem with that. Put in download mode again forcing several times if necessary volume - Power and home until reaching download mode. Once this is achieved, flash with Odin the latest firmware version. What binary do you have in your file inside the phone? | |
![]() | #6 (permalink) | |
Member: 2549245 Status: Offline Thanks Meter: 2 | Quote:
![]() | #7 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,274 ![]() | Hello bro are you sure that you flashed combination b:4 not b:5 ? if yes you should be able to flash b:4 software but if you get red (sw rev check ) while flashing you need to flash latest firmware with binary 4 or binary 5 ( 4 files firmware ) Quote:
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON | |
![]() | #8 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | It is very important what the user says souma_k to be able to help you in the process of recovering the phone. It would also be interesting to know so that you want to flash with an engineering file and if you did any xon Z3X process that has gone wrong, you could upload the logo of the operation to know what error you have had. Could you put the phone in download mode and take a screenshot to upload it to the forum? On that screen you could know that binary has the firmware that currently has your phone. |
![]() | #9 (permalink) | |
Member: 2549245 Status: Offline Thanks Meter: 2 | [QUOTE=souma_k;12278749]Hello bro are you sure that you flashed combination b:4 not b:5 ? if yes you should be able to flash b:4 software but if you get red (sw rev check ) while flashing you need to flash latest firmware with binary 4 or binary 5 ( 4 files firmware ) Yes, I flashed combination b:4 and flash b:4 latest firmware. Quote:
![]() Screen 2,Next operation flash firmware, but after reboot and start into phone upgrade\install firmware, process stop on 32% and start process Erase. After Erase can see next screen ![]() Screen 3, then open Recovery ![]() Screen 4, after reboot we can see next screen and again open Recovery or stuck on this screen. ![]() Screen 5, After last flashed stuck on logo SAMSUNG like screen ![]() | |
![]() | #12 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,274 ![]() | https://we.tl/EdFY746Pqk Bro try this firmware it is from Luxembourg binary 4 security 2 4 files firmware hope it will help you IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
![]() | #14 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,274 ![]() | bro please check the water damage stickers when you remove the simcard try maybe the problem persistes is cozd by hardware not software |
