07-26-2017, 13:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | G930A unlock problem Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 6.0.1 Product code: SM-G930AZKAATT Phone version: G930AUCS4API2 PDA version: G930AUCS4API2 CSC version: G930AATT4API2 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R38H203XCKE Chip name: MSM8996 Modem board: MSM8996 Security patch: 2016-09-01 RF cal date: 2016.02.10 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM54 detected Reading data from phone... error (3) Done with Samsung Tool PRO v.29.0 |
08-22-2017, 12:54 | #3 (permalink) |
Registered User Join Date: Nov 2010 Age: 47
Member: 1452501 Status: Offline Sonork: 00000 Thanks Meter: 2 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. Operation: Read Codes via Server Selected model: SM-G930A Selected port: COM3 USB Serial Port Software version: 29.1 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G930A Android version: 7.0 Product code: SM-G930AZDAATT Phone version: G930AUCU4BQD4 PDA version: G930AUCU4BQD4 CSC version: G930AATT4BQD4 CSC country code: USA CSC sales code: ATT HW version: REV0.6 Phone SN: R58H965XAVR Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-04-01 RF cal date: 2016.10.01 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM28 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 46303909 NET lock: 31468249 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 GOOD |
