Old 03-28-2017, 14:52   #1 (permalink)
Member: 2404520
G930f g935f samsung s7 , patch , signal problem , imei repair , double imei .
I change the imei on g930f but for some reason it shows two . One imei is with numbers that I type in the box and secund one that i did not mark and left empty is 0000000.....
Well the phone works fine after patch firmwarr but every month it losing the signal permanently and I need to keep patching it ANY IDEA WHY ?
I got very tired becouse of this .
Thanks
Samsung s7 G930F
Old 03-28-2017, 19:18   #2 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 73
BEcause have hardware write second imei replace sim holder to dual sim holder
Old 03-28-2017, 20:10   #3 (permalink)
Member: 2695168
Thanks Meter: 7
Writing both IMEIs to G930F doesn't work. And why would a single sim phone owned would ever want to convert to dual sim?
Old 03-28-2017, 21:47   #4 (permalink)
Member: 2404520
Hi,
When I type Repair imei in Z3x I will have 2 lines with imei numbers .
I did not mark or touch second box at all but it still write second imei as 0000000.....
Well I don't care about second imei .
The problem is that in about every one month it will lose signal permanently and my question is WHY AND / OR HOW TO FIX IT ?
Thanks
Old 03-30-2017, 12:50   #5 (permalink)
Member: 2404520
Any suggestion lads ...
Old 03-31-2017, 22:37   #6 (permalink)
Member: 2404520
Old 04-05-2017, 10:34   #7 (permalink)
Member: 88864
Thanks Meter: 10
same problem here
second imei activated after repair?also all dual sim controls.how to get back to single sim?
also model number changed to g930fd.tryedto flash other fw still same.
Old 04-05-2017, 18:33   #8 (permalink)
mk
mk's Avatar
Member: 199768
Thanks Meter: 16,170
Post here your FW
br
Old 04-06-2017, 16:29   #9 (permalink)
Member: 1574069
Thanks Meter: 32
How to convert G930F/G935F double IMEI back to single. After Z3X IMEI repair on single IMEI showing 2 IMEI. One with repaired IMEI and second one 0000000000000000
Old 04-18-2017, 14:29   #10 (permalink)
Member: 2404520
I personally newer saw even one answer from Z3X teem about double imei or losing signal repair ( how to fix this issue ) .
I hate to say but it looks like imei repair can be used temporary so basically its looks like it's a fake update just for few days or a month .
If anyone's will know it do not work properly then no one will even try this and just sell the phone to different county .
This can be only used for people who do it and sell the phone imediently to someone that have no idea about this .
I really think we should know about this huge problem before we try this on our phoones or customers or friends !
The Following User Says Thank You to samsungcork For This Useful Post:
Old 05-24-2017, 23:09   #11 (permalink)
Member: 2404520
Any news Z3X tem? has bean a long time and no one try to answer solution in this big problem we are having with it . I know someone read the massage so maybe wake up call will help a little bit !
Old 05-24-2017, 23:15   #12 (permalink)
Member: 2404520
no chance dear , do it your self and you will see and then comment . We need help / solution not drama . thanks for understanding
Old 05-25-2017, 00:23   #13 (permalink)
Member: 120273
Thanks Meter: 57
I guess you tried the obvious and write same imei in both sections? does that work?
Old 05-25-2017, 05:52   #14 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 292
G935F after repair network dual imei FIXED
Old 05-25-2017, 05:54   #15 (permalink)
Member: 2262368
Thanks Meter: 57
you can fix it with latest z3x version. to single imei only or dual imei. even if you write 2 imei's the phone will work ok. now you can replace the sim card tray and get dual sim s7
Page generated in 0.17677 seconds with 8 queries
