03-28-2017, 14:52 | #1 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2404520 Status: Offline Thanks Meter: 1 | G930f g935f samsung s7 , patch , signal problem , imei repair , double imei . Well the phone works fine after patch firmwarr but every month it losing the signal permanently and I need to keep patching it ANY IDEA WHY ? I got very tired becouse of this . Thanks Samsung s7 G930F |
03-28-2017, 21:47 | #4 (permalink) |
Member: 2404520 Status: Offline Thanks Meter: 1 | Hi, When I type Repair imei in Z3x I will have 2 lines with imei numbers . I did not mark or touch second box at all but it still write second imei as 0000000..... Well I don't care about second imei . The problem is that in about every one month it will lose signal permanently and my question is WHY AND / OR HOW TO FIX IT ? Thanks |
04-05-2017, 10:34 | #7 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 46
Member: 88864 Status: Offline Thanks Meter: 10 | same problem here second imei activated after repair?also all dual sim controls.how to get back to single sim? also model number changed to g930fd.tryedto flash other fw still same. |
04-06-2017, 16:29 | #9 (permalink) |
Freak Poster Join Date: May 2011 Location: United Kingdom
Member: 1574069 Status: Offline Thanks Meter: 32 | How to convert G930F/G935F double IMEI back to single. After Z3X IMEI repair on single IMEI showing 2 IMEI. One with repaired IMEI and second one 0000000000000000 |
04-18-2017, 14:29 | #10 (permalink) |
Member: 2404520 Status: Offline Thanks Meter: 1 | I personally newer saw even one answer from Z3X teem about double imei or losing signal repair ( how to fix this issue ) . I hate to say but it looks like imei repair can be used temporary so basically its looks like it's a fake update just for few days or a month . If anyone's will know it do not work properly then no one will even try this and just sell the phone to different county . This can be only used for people who do it and sell the phone imediently to someone that have no idea about this . I really think we should know about this huge problem before we try this on our phoones or customers or friends ! |
The Following User Says Thank You to samsungcork For This Useful Post: |
05-24-2017, 23:09 | #11 (permalink) |
Member: 2404520 Status: Offline Thanks Meter: 1 | Any news Z3X tem? has bean a long time and no one try to answer solution in this big problem we are having with it . I know someone read the massage so maybe wake up call will help a little bit ! |
05-25-2017, 05:54 | #15 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | you can fix it with latest z3x version. to single imei only or dual imei. even if you write 2 imei's the phone will work ok. now you can replace the sim card tray and get dual sim s7 |
