03-13-2017, 18:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | G935F 7.0 FRP/React reset how ? I try but get this: Code: Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM64 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.8 Then download FW G935F_XXU1DQAS_OXE1DQAS.zip and make mobile live again. Again try and get this. Then read here to downgread to 6.0.1 From support download this G935F_XXU1BPLB_OXE1BPKJ.zip Flash mobile with it, make Wipe, start mobile and go to page for e-mail. Then again try FRP/React - and get same result: Code: Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM64 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.8 |
03-13-2017, 23:26 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro downgrade to older version and try reset frp ee the old method not adb it should work IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON |
03-14-2017, 04:27 | #4 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
6.0.1 SM-G935F G935FXXU1APB3 02/04/2016 6.0.1 SM-G935F G935FXXU1APAW 01/29/2016 100% | |
03-14-2017, 04:33 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Another alternative method that could be done is the following: -Download and flash the EngBoot file via odin https://www.4shared.com/file/j5m0LLd...APG2_boot.html -This will activate adb. Run the command for activation Adb shell content insert --url content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 - Enable oem unlock - Connect the phone to normal mode and perform FRP with the tool That supports the FRP function |
