07-22-2017, 03:57 | #1 (permalink) |
Junior Member Join Date: Jan 2016 Location: Ecuador
Member: 2522593 Status: Offline Thanks Meter: 13 | G935F Reset Frp UFS DONE Metodo (method): Reset Frp UFS Cable: uart C3300K *** Spanish *** 1. Teléfono totalmente apagado y desconectado. 2. Seleccionar el puerto COM: Z3x Box Serial Port 3. Seleccionar en RESET FRP UFS. 4. En ese momento conectamos el telefono con el cable uart y el equipo debe estar apagado. 5. Una ves conectado Presionar por 2 o 3 segundos Volumen Down + Power. Inmeditamente detectara el puerto y en 3 segundos el equipo estara Listo.. NO Sboot, NO Combination file, NO Enabled Adb, etc etc *** English *** 1. phone off and disconnected 2. Select COM PORT: Z3x Box Serial Port 3. Select RESET FRP UFS. 4. Connect Uart Cable. 5. Press 2 or 3 seconds Vol Down + Power. In few a seconds --> DONE NO Sboot, NO Combination file, NO Enabled Adb, etc etc |
The Following 4 Users Say Thank You to christian_cnc For This Useful Post: |
07-22-2017, 16:37 | #2 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 38
Member: 599024 Status: Offline Thanks Meter: 18 | not done by me UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP UFS Selected model: SM-N920T Selected port: COM5 USB Serial Port Software version: 28.8 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM5 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (N920T) Setup connection... error (2) Done with Samsung Tool PRO v.28.8 |
10-05-2017, 08:20 | #3 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Armenia Age: 36
Member: 1795596 Status: Offline Thanks Meter: 30 | Reset FRP UFS com babel c3300k Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.4 android 7 G935FXXU1DQAS_SER_10273029 |
04-05-2018, 07:34 | #4 (permalink) |
Insane Poster Join Date: Mar 2016 Location: depalpur distt okara
Member: 2553465 Status: Offline Thanks Meter: 19 | To mr.blung dear sir, how would people know that u have to select this model instead of this model for example a520f to 928t for removing frp in ufs procedure. These must be mentioned in software procedure |
