03-10-2019, 18:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: usa
Member: 444048 Status: Offline Thanks Meter: 52 | G960U T-Mobile It Was Google Locked, After Flash Combination[Answered] Operation: Flash Selected model: SM-G960U Software version: 34.11 File analysis... OK Total file size: 0xA5DE672B (2653 Mb) Searching USB Flash interface... COM4 detected Setup connection... OK Getting device info... OK Set PIT file... OK Reading PIT from phone... OK Sending abl.elf... OK Sending xbl.elf... OK Sending xbl_config.elf... OK Sending tz.mbn... OK Sending hyp.mbn... OK Sending devcfg.mbn... OK Sending pmic.elf... OK Sending aop.mbn... OK Sending cmnlib.mbn... OK Sending cmnlib64.mbn... OK Sending keymaster64.mbn... OK Sending qupv3fw.elf... OK Sending sec.dat... OK Sending apdp.mbn... OK Sending msadp.mbn... OK Sending bksecapp.mbn... OK Sending storsec.mbn... OK Sending vaultkeeper.mbn... OK Sending engmode.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending vendor.img.ext4... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending dqmdbg.img.ext4... OK Sending carrier.img.ext4... OK Sending modem.bin... OK Sending dspso.bin... OK Sending cache.img.ext4... OK Sending odm.img.ext4... OK Sending userdata.img.ext4... |
03-10-2019, 19:24 | #2 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | U flash a lower binary than that was on the phone,that's what u ended up with a dead phone,you will need loader unbrick files for your device model,after success u can return to download mode and flash stock. |
03-13-2019, 19:41 | #9 (permalink) |
Insane Poster Join Date: Apr 2017 Location: Anaheim California
Member: 2710649 Status: Offline Thanks Meter: 47 | Its simply you have a brick device its weird that it got brick by that unless if the device was updated to 9.0 "PIE" maybe 9.0 and try to flash combination firmware will not accept, for example J327P,J727P with FRP when flashing combination firmware after device would be brick so u have to be careful, so only way to avoid that is to flash a lower firmware with same Bit version and after flash combination firmware, Like other poster said only way to bring back device from that mode is unbrick first so u can enter download mode after flash stock... |
03-13-2019, 20:43 | #10 (permalink) | |
Member: 444048 Status: Offline Thanks Meter: 52 | g960u frp Quote:
