03-28-2019, 20:47 | #1 (permalink) |
Insane Poster Join Date: Feb 2018 Location: USA
Member: 2811770 Status: Offline Thanks Meter: 8 | Google Account locked on Sm-T580 [Answered] FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-T580 Software version: 35.2 File analysis... OK Total file size: 0x005ED090 (5 Mb) Searching USB Flash interface... COM34 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending modem.bin... OK Flashing done (time - 00:00:05) Done with Samsung Tool PRO v.35.2 |
03-28-2019, 22:36 | #2 (permalink) |
Member: 2811770 Status: Offline Thanks Meter: 8 | I'm trying to add the picture which is only 78.3Kb but Im getting this rsz_20190328_144153(1).jpg: Upload of file failed. I hosted that picture somewhere else there is the link for it https://ibb.co/Cz6xdGZ when I try combination file I get error saying frp is on can't write files. when I try to use Z3x box it says ADB needs to be on, which isn't on, so I dont know what to do, I can't simply upload one file to this website even. Last edited by zfk110; 03-28-2019 at 22:43. |
03-29-2019, 02:20 | #4 (permalink) |
Member: 2811770 Status: Offline Thanks Meter: 8 | that will put back the stock firmware back which I already have, but when I go through setup its asking me google account info which I don't have so I stuck there, how to by pass that? |
03-29-2019, 03:01 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,054 | Try this... https://www.youtube.com/watch?v=Jf6rBqldmYc or this http://forum.gsmhosting.com/vbb/f200.../#post13566119 Br, xerraco |
The Following User Says Thank You to xerraco For This Useful Post: |
