06-21-2020, 17:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2693973 Status: Offline Thanks Meter: 10 | GT-i9060i ending system.img... error timeout [Answered] 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: GT-I9060I/DS Software version: 40.5 File analysis... OK Total file size: 0x3E13E8D8 (993 Mb) Searching USB Flash interface... COM6 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending spl.img... OK Sending sboot.bin... OK Sending sboot2.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... error timeout Done with Samsung Tool PRO v.40.5 |
06-21-2020, 18:03 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | Hi you need to check your firmware if is compatible and you can try Unmark all and select only 2 file boot.img and recovery.img After flash this 2 file hard reset phone |
06-22-2020, 09:40 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
10-14-2021, 21:27 | #4 (permalink) |
Insane Poster Join Date: Nov 2019 Location: Ethiopia,addis ababa
Member: 2934913 Status: Offline Thanks Meter: 12 | Operation: Flash Selected model: GT-I9060I/DS Software version: 43.16 File analysis... OK Total file size: 0x3A145B80 (929 Mb) Searching USB Flash interface... COM18 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending spl.img... OK Sending sboot.bin... OK Sending sboot2.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... error timeout Done with Samsung Tool PRO v.43.16 Any one help? |
10-15-2021, 07:54 | #5 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,058 | Quote:
