07-25-2010, 16:17 | #16 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 95476 Status: Offline Thanks Meter: 185 | then connecte port and connect port phone then connecte phone without battrie /////////////////////////////////////////////////////////// Phone type : LG-GW520 Phone IMEI : 353638-03-36xxxx-x Connecting phone - connect USB cable to phone, phone must be OFF and without battery ... Driver connected, connecting phone ... OK ---------------------------------------------------------- Changing baudrate ... OK Setting bus ... OK Loading certificate ... OK ---------------------------------------------------------- Reading phone info ... OK ---------------------------------------------------------- Reading sim unlock code... OK Sim unlock code : 2791 8013 6272 8431 ======== Process completed ======== Operation time - 00:01 ---------------------------------------------------------- For operation finishing,do next : - power phone ON without SIM - type 2945#*71001# to enter unlock menu - enter unlock code : 2791 8013 6272 8431 |
The Following User Says Thank You to lader For This Useful Post: |
10-20-2010, 05:12 | #17 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1422557 Status: Offline Thanks Meter: 1 | Help !!!! He hello , ive tried to run the lg unlocker several times without any succes , please help me . my mobile model : GW520 IMEI: 353638033475658 |
The Following User Says Thank You to Janus777 For This Useful Post: |
12-01-2010, 01:52 | #20 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Spain Age: 47
Member: 41412 Status: Offline Thanks Meter: 18 | Install first phone drivers or LGPCSuiteIII. choose USB and correct port. Phone off, press read and conect usb cable. 2 seconds and have your code. BR. |
05-18-2011, 17:34 | #21 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1049259 Status: Offline Thanks Meter: 14 | Detailed EEPROM Information: EEPROM Model: 0 EEPROM Manufacturer: lec. Inc EEPROM Version: 23 2009 EEPROM IMEI : 35363803393670900 EEPROM BT Adress : 20:21:A5:08:B7:94 Detailed Codes Information: EEPROM NCK Code : 7058-0356-7967-4273 EEPROM NS Code : 2596-0044-5033-3867 EEPROM SP Code : 6743-3175-2262-8839 EEPROM CP Code : 8317-6031-8114-7903 EEPROM SIM Code : 7002-9631-5299-3569 Ready. Opening "GW520_autobackup_18052011_140206.eep"... Writing EEPROM... Sending SEC pack... Writing done! Finished in 2 seconds |
06-14-2011, 10:19 | #22 (permalink) |
Junior Member Join Date: May 2011
Member: 1575211 Status: Offline Thanks Meter: 1 | hi i've doing the same for unlocking a gw520 Please connect phone , it must be powered off Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Archivos de programa\Z3X\LG\LGI_SG3\BACKUP\GW520_autobackup_13 062011_204521.eep Analising EEPROM... Detailed Phone Information: Phone Model: 0 Phone Manufacturer: lec. Inc Phone Version: 23 2009 Phone IMEI : 35363803374556300 Phone BT Adress : 00:26:E2:65:F3:3F Detailed Codes Information: Phone NCK Code : 0146-5241-0721-9958 Phone NS Code : 2698-0105-6673-8814 Phone SP Code : 6867-3238-3712-5976 Phone CP Code : 1384-3715-1979-5690 Phone SIM Code : 7126-0794-5730-8626 SimLocks Disabled SP Lock Enabled CP Lock Disabled NS Lock Disabled SIM Lock Disabled AT Lock Disabled SL Config:21403FFFFFFFFFFFFFFFFFFF Finished in 0 seconds Reading ... Sending SEC pack... Finished in 0 seconds Unlocking... Sending SEC pack... Error clearing port and i click in unlock,direct,do it,but when i power the phone the screen is yellow. any solution? please. |
GD900 AND GW520 Succes unlocked thx for good updates | Secgsm | VygisToolbox | 8 | 02-23-2011 10:34 |
succesfully unlock i5700 with usb | LABOSSEF | NSPRO | 5 | 09-08-2010 07:15 |
GW520 succesfully unlocked S3GOLD 2.1.0.54 [Report OK] | janda | Z3X-Team Products | 0 | 12-09-2009 10:50 |
