Old 02-02-2017, 13:28   #691 (permalink)
Member: 1908127
Thanks Meter: 14
wrote 1000 times no answer
smart card need update so much bad support
Old 02-02-2017, 18:44   #692 (permalink)
Member: 2530835
got NV data error 1 58 when reading unlock code
] Operation: Read Codes
[ 2/2/2017 12:31:00 PM ] Selected model: SM-G928W8
[ 2/2/2017 12:31:00 PM ] Software version: 27.7
[ 2/2/2017 12:31:00 PM ] Searching Samsung modem... detected COM110
[ 2/2/2017 12:31:00 PM ] Reading phone info... Ok
[ 2/2/2017 12:31:00 PM ] Model: SM-G928W8
[ 2/2/2017 12:31:00 PM ] AP version: G928W8VLU4BPK4
[ 2/2/2017 12:31:00 PM ] CSC version: G928W8OYA4BPK4
[ 2/2/2017 12:31:00 PM ] CP version: G928W8VLU4BPK4
[ 2/2/2017 12:31:00 PM ] Product code: SM-G928WZKAGLW
[ 2/2/2017 12:31:00 PM ] Phone SN: R58G90SA1GD
[ 2/2/2017 12:31:00 PM ] Unique number: 0715F7F045C61105
[ 2/2/2017 12:31:00 PM ] Reading IMEI... Ok
[ 2/2/2017 12:31:00 PM ] IMEI: 3525******0 (SIGN: OK)
[ 2/2/2017 12:31:00 PM ] Checking hash file... Ok
[ 2/2/2017 12:31:00 PM ] Reading data from phone... Ok
[ 2/2/2017 12:31:00 PM ] Modem board: SHANNON333
[ 2/2/2017 12:31:00 PM ] HWID: 4* ** 11 3* *7 0* 00 00 00 00 00 00 00 00 00 00
[ 2/2/2017 12:31:00 PM ] Reading NV data... error (1 58)
getting error reading code on a S6 edge+ G928w8
Old 02-02-2017, 20:01   #693 (permalink)
Member: 387971
Thanks Meter: 64
Cpu info for each phone will be nice
Old 02-03-2017, 04:10   #694 (permalink)
Member: 2430694
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-G930F
File analysis... Ok
Total file size: 0x108A85910 (4234 Mb)
Searching USB Flash interface... COM3 detected
Setup connection... Ok
Reading PIT from phone... Ok
Sending sboot.bin... Ok
Sending param.bin... Ok
Sending cm.bin... Ok
Sending boot.img... Ok
Sending recovery.img... Ok
Sending system.img... error
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G930F" "Sending system.img error" - Пошук Google
Done with Samsung Tool PRO v.27.7
Old 02-03-2017, 09:47   #695 (permalink)
Member: 2105491
Sonork: 1614736
Thanks Meter: 16
IMEI Repair working fine but Patch Network is not working at all
posted so many times but Z3X team is sleeping somewhere
Samsung J5 Prime
model : G570f
OS : Android OS, v6.0.1 (Marshmallow)
Chipset : Exynos 7570 Quad
CPU : Quad-core 1.4 GHz Cortex-A53
Old 02-05-2017, 13:02   #696 (permalink)
Member: 2105491
Sonork: 1614736
Thanks Meter: 16
Samsung J5 Prime
model : G570f
Old 02-05-2017, 13:03   #697 (permalink)
Member: 2105491
Sonork: 1614736
Thanks Meter: 16
z3x support is sleeping i think
still waiting for samsung g570f network repair
if you guys are not sure about the update that it will gonna work for sure
then why you launch that
like
you launched g570f imei repair and network repair
but network repair is not working
sooooooooooo please help us out
Old 02-05-2017, 13:04   #698 (permalink)
Member: 2105491
Sonork: 1614736
Thanks Meter: 16
G570f network repair problem
Samsung J5 Prime
model : G570f
Old 02-06-2017, 09:21   #699 (permalink)
Member: 2105491
Sonork: 1614736
Thanks Meter: 16
no body is replying at all
Old 02-06-2017, 16:33   #700 (permalink)
Member: 2047179
Thanks Meter: 31
samsung g530t1 Frp unlock failed
Samsung g530t1 Frp unlock failed with z3x. Please solve this problem or give combination file for enable adb mode.
Old 02-06-2017, 16:34   #701 (permalink)
Member: 1908127
Thanks Meter: 14
they sleeeeeeeping man understand
look how many time i wrote them no really answer or help
Old 02-22-2017, 20:04   #702 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 115
It would be great to be able to patch cert on all G870's.
Old 03-05-2017, 00:43   #703 (permalink)
Member: 2381269
sgh-a997
UNLOCK INSTRUCTIONS:
Micro-UART cable only:
1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
2. Connect phone and press power button.
Selected model: SGH-A997
Selected port: COM47 USB Serial Port
Connect phone and press power button Timeout
what i have to do
Old 03-06-2017, 13:38   #704 (permalink)
Member: 2514690
When the new updates of z3x samsung will come ????
Old 03-07-2017, 15:24   #705 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
Few more months to never......probably...I hope not😰
Page generated in 0.18373 seconds with 9 queries
