03-26-2013, 13:27 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1344199 Status: Offline Thanks Meter: 13 | Help for Galaxy S5360T unlocking We cannot root it or something el.... We install ''universal_gb_root_v25.zip'' But supersu cannot open it says- "There is no su binary installed,and supersu cannot install it this is a probllem'' Whats da worong with it Or us. PLZ guid us step by step Specially Request goes to z3x Support team LOG with Z3X here...... |
03-26-2013, 13:32 | #2 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | 1st root phone via srsroot then try............ |
The Following User Says Thank You to [email protected] For This Useful Post: |
03-26-2013, 15:25 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Uncheck ADB In Phone Settings Application>Development Attach Cable Select Usb Modem Port Do Unlock OR Read Codes. BR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
03-28-2013, 06:53 | #4 (permalink) | |
Member: 1344199 Status: Offline Thanks Meter: 13 | Quote:
But 11:35:18 AM [+] Testing exploit: root3 (Please wait some minutes) 11:35:19 AM [+] Executing root3 exploit Failed. (Root Error: 0) 11:35:19 AM [+] Installing exploit: root3c (Please wait...) 11:35:25 AM [+] Select 'FRODO' on your device, then click OK 11:35:27 AM [+] Removing Exploit.. Please Wait.. 11:35:33 AM [+] Analysing Results... 11:35:35 AM [+] Auto-Root not possible on your device. Whats d hell is going on Device | |
03-28-2013, 07:06 | #5 (permalink) | |
But If u mean uncheck ''USB debugging'' After unchecked Z3X not found phone LOG- Selected model: S5360T Selected port: COM37 SAMSUNG Mobile USB OBEX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.14.1 | |
The Following User Says Thank You to pradip980492750 For This Useful Post: |
03-28-2013, 08:28 | #6 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | root your phone manually then try , i hope your problem will b solve press thanks if u like my post.... |
The Following User Says Thank You to max_cool For This Useful Post: |
03-30-2013, 11:10 | #10 (permalink) |
Member: 1344199 Status: Offline Thanks Meter: 13 | Finally Ive got d solution by applying 'Universal_GB_ROOT_v5.zip','Universal_GB_ROOT_v8.z ip','Universal_GB_ROOT_v9.zip','universal_gb_root_ v18.zip'' turn by turn. And after root easily unlock by z3x Thanks z3x and thanks to all ... [email protected],.::MASTER ALONE::.,max_cool and cycofcgb |
03-30-2013, 17:29 | #11 (permalink) | |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
05-13-2013, 15:29 | #14 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
can u pls share the other root files? i hve ver9 but not the remaining as ur solution is good if we dont want to downgrade the phone! WBR ReyTech. | |
