08-11-2009, 07:22 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | First you update the latest setup LGQ 1.5.8.And second one is Your hand set is unlocked after flashing.First flash your handset with ku990i firmware and after press the unlock button.Your handset is unlocked successfully.Before I already unlocked two handsets successfully. |
The Following User Says Thank You to caremobiles For This Useful Post: |
08-11-2009, 17:05 | #3 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | 1. Donwload ku990i flash. 2. Check Manual model select in option. 3. Select ku990i. 4. Select firmware. 5. Press Flash button. 6. Press Unlock button. 7. Done -- andrew_tm 2009 |
The Following 2 Users Say Thank You to andrew_tm For This Useful Post: |
09-02-2009, 19:38 | #4 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | thanks it worked 100% 02-09-2009 18:55:22: v.1.6.0 02-09-2009 18:55:22: supported models: 65 02-09-2009 18:55:22: andrew_tm 2009(c) 02-09-2009 18:55:22: 02-09-2009 18:55:35: Mode: Normal 02-09-2009 18:55:35: Model: KU990iG 02-09-2009 18:55:35: Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG 02-09-2009 18:55:35: SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX 02-09-2009 18:55:35: IMEI: 35469303541873-6 02-09-2009 18:55:35: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 18:55:35: Flash Name: toshiba_tya000bc00bogg 02-09-2009 18:55:35: Flash Info: 06C3/0040/0800 02-09-2009 18:55:35: Elapsed: 0 secs. 02-09-2009 18:55:35: 02-09-2009 18:55:36: Mode: Normal 02-09-2009 18:55:36: Model: KU990iG 02-09-2009 18:55:36: Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG 02-09-2009 18:55:36: SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX 02-09-2009 18:55:36: IMEI: 35469303541873-6 02-09-2009 18:55:36: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 18:55:36: Flash Name: toshiba_tya000bc00bogg 02-09-2009 18:55:36: Flash Info: 06C3/0040/0800 02-09-2009 18:55:36: Elapsed: 0 secs. 02-09-2009 18:55:36: 02-09-2009 18:55:42: Reading file as KU990i... 02-09-2009 18:55:51: Original Firmware file: 02-09-2009 18:55:51: KU990i-DZ-V10b-MAR-12-2009-OPN-EU 02-09-2009 18:55:51: 02-09-2009 18:56:04: Mode: Normal 02-09-2009 18:56:04: Model: KU990iG 02-09-2009 18:56:04: Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG 02-09-2009 18:56:04: SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX 02-09-2009 18:56:04: IMEI: 35469303541873-6 02-09-2009 18:56:04: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 18:56:04: Flash Name: toshiba_tya000bc00bogg 02-09-2009 18:56:04: Flash Info: 06C3/0040/0800 02-09-2009 18:56:04: Elapsed: 0 secs. 02-09-2009 18:56:04: 02-09-2009 18:56:05: NV read... 02-09-2009 18:56:07: Block 25 reading failed. 02-09-2009 18:56:07: Block 26 reading failed. 02-09-2009 18:56:07: Block 27 reading failed. 02-09-2009 18:56:07: Block 29 reading failed. 02-09-2009 18:56:14: Block 216 reading failed. 02-09-2009 18:56:16: Block 257 reading failed. 02-09-2009 18:56:17: Block 299 reading failed. 02-09-2009 18:56:18: Block 319 reading failed. 02-09-2009 18:56:23: Block 466 reading failed. 02-09-2009 18:56:27: Block 580 reading failed. 02-09-2009 18:56:37: Block 889 reading failed. 02-09-2009 18:56:38: Block 906 reading failed. 02-09-2009 18:56:38: Block 920 reading failed. 02-09-2009 18:56:48: Block 1192 reading failed. 02-09-2009 18:56:52: Block 1311 reading failed. 02-09-2009 18:59:04: NV save:..\backup\KU990i_354693035418736_02092009_185 605.cnv 02-09-2009 18:59:04: Elapsed: 180 secs. 02-09-2009 18:59:04: 02-09-2009 18:59:05: Start Flash... 02-09-2009 18:59:05: Modem Write Start... 02-09-2009 19:04:57: Flash Verify Done. 02-09-2009 19:05:01: EFS Erase Done. 02-09-2009 19:05:01: Modem Write Done. 02-09-2009 19:05:01: Phone Reboot. 02-09-2009 19:05:46: Phone Detected! 02-09-2009 19:05:46: Write NV... 02-09-2009 19:06:10: EFS Write Start... 02-09-2009 19:06:10: Start Write Media... 02-09-2009 19:20:39: Start Write Module... 02-09-2009 19:29:12: EFS Write Done. 02-09-2009 19:29:12: Flash Done. 02-09-2009 19:29:12: Elapsed: 1807 secs. 02-09-2009 19:29:12: 02-09-2009 19:30:17: Mode: Normal 02-09-2009 19:30:17: Model: KU990i 02-09-2009 19:30:17: Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i 02-09-2009 19:30:17: SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX 02-09-2009 19:30:17: IMEI: 35469303541873-6 02-09-2009 19:30:17: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 19:30:17: Flash Name: toshiba_tya000bc00bogg 02-09-2009 19:30:17: Flash Info: 06C3/0040/0800 02-09-2009 19:30:17: Elapsed: 0 secs. 02-09-2009 19:30:17: 02-09-2009 19:30:19: Mode: Normal 02-09-2009 19:30:19: Model: KU990i 02-09-2009 19:30:19: Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i 02-09-2009 19:30:19: SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX 02-09-2009 19:30:19: IMEI: 35469303541873-6 02-09-2009 19:30:19: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 19:30:19: Flash Name: toshiba_tya000bc00bogg 02-09-2009 19:30:19: Flash Info: 06C3/0040/0800 02-09-2009 19:30:19: Elapsed: 0 secs. 02-09-2009 19:30:19: 02-09-2009 19:30:21: Mode: Normal 02-09-2009 19:30:21: Model: KU990i 02-09-2009 19:30:21: Build version: Mar 31 200920:23:46FEB 13 200917:00:00KU990i 02-09-2009 19:30:21: SW Version: KU990i-MSM6280-V10b-MAR-12-2009-XX 02-09-2009 19:30:21: IMEI: 35469303541873-6 02-09-2009 19:30:21: BlueTooth Address: 00:24:83:56:76:9E 02-09-2009 19:30:21: Flash Name: toshiba_tya000bc00bogg 02-09-2009 19:30:21: Flash Info: 06C3/0040/0800 02-09-2009 19:30:21: Elapsed: 0 secs. 02-09-2009 19:30:21: 02-09-2009 19:30:26: Firmware signature in base: 151 02-09-2009 19:30:26: Ver: Mar 31 200920:23:46FEB 13 200917:00:00KU990i 02-09-2009 19:30:26: Signature detected! 02-09-2009 19:30:26: Start send loader... 02-09-2009 19:30:28: Loader startup OK... 02-09-2009 19:30:28: Flash IC name: toshiba_tya000bc0 02-09-2009 19:30:29: Security backup saved to: 02-09-2009 19:30:29: C:\Programas\Z3X\LG\LGQ\Backup\KU990i_354693035418 736_02092009_193029.sec 02-09-2009 19:30:30: Erase sec. zone... 02-09-2009 19:30:30: Write data to phone... 02-09-2009 19:30:33: Phone rebooted! 02-09-2009 19:30:33: Elapsed: 9 secs. 02-09-2009 19:30:33: |
09-07-2009, 19:22 | #5 (permalink) |
Freak Poster Join Date: May 2006 Location: Dabrowa Bialostocka/Poland
Member: 280760 Status: Offline Thanks Meter: 7 | i fllsahed with firmware but v.1.6.2 supported models: 68 andrew_tm 2009(c) Mode: Normal Model: KU990iG Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KU990iG Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 153 Ver: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG Not support version! Dump firmware and send to support! Elapsed: 3 secs. Port already opened! Elapsed: 0 secs. Reading file as KU990i... Ok Original Firmware v2.0 Firmware Name:KU990i_V10d-MAR-20-2009-VDF.bin Firmware Languages list: [Bulgarian] [Category] [Croatian] [Czech] [Danish] [Dutch] [English] [Estonian] [Finnish] [French] [German] [Greek] [HeaderI] [Hungarian] [Italian] [Kazakh] [Latvian] [Lithuanian] [Norvegian] [Polish] [Portuguese] [Romanian] [Russian] [Slovak] [Slovenian] [Spanish] [Swedish] [Turkish] [Ukrainian] [Bulgarian] [Category] [Croatian] [Czech] [Danish] [Dutch] [English] [Estonian] [Finnish] [French] [German] [Greek] [HeaderI] [Hungarian] [Italian] [Kazakh] [Latvian] [Lithuanian] [Norvegian] [Polish] [Portuguese] [Romanian] [Russian] [Slovak] [Slovenian] [Spanish] [Swedish] [Turkish] [Ukrainian] Mode: Normal Model: KU990iG Build version: Mar 22 200914:00:12MAR 11 200917:00:00KU990iG SW Version: KU990iG-MSM6280-V10c-MAR-11-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. NV read... NV save:..\backup\KU990i_354693032787293_07092009_193 746.cnv Elapsed: 79 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 2106 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 153 Ver: Mar 22 200917:28:48MAR 20 200917:00:00KU990i Not support version! Dump firmware and send to support! Elapsed: 3 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. NV read... NV save:..\backup\KU990i_354693032787293_07092009_201 643.cnv Elapsed: 14 secs. Select Modem Port:COM15 Detect phone Ok! Start Unlock Unlock ERROR! Elapsed: 15 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 153 Ver: Mar 22 200917:28:48MAR 20 200917:00:00KU990i Not support version! Dump firmware and send to support! Elapsed: 3 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Mode: Normal Model: KU990i Build version: Mar 22 200917:28:48MAR 20 200917:00:00KU990i SW Version: KU990i-MSM6280-V10d-MAR-20-2009-XX IMEI: 35469303278729-3 BlueTooth Address: 00:24:83:1F:3F:4B Flash Name: toshiba_tya000bc00bogg Flash Info: 06C3/0040/0800 Elapsed: 0 secs. Firmware signature in base: 155 Ver: Mar 22 200917:28:48MAR 20 200917:00:00KU990i Not support version! Dump firmware and send to support! Elapsed: 3 secs. |
E250 direct unlocked [Report OK] | R@ZIB-BD | Z3X-Team Products | 1 | 03-20-2015 13:19 |
is it possible to unlock iphone 2g updated from 112 to 202 ?? help needed | ataur0008 | iPhone 2 / iPhone 3G / iPhone 3GS | 6 | 08-24-2008 19:36 |
Is it possible to unlock an apple iphone 1.1.2 to older versions? | doc9587 | iPhone 2 / iPhone 3G / iPhone 3GS | 24 | 12-30-2007 19:48 |
K700 Transformed from CID 29 to CID 36, now possible to unlock with Cruiser? | Megaron | Cruiser Suite | 4 | 05-12-2005 13:44 |
