04-20-2021, 13:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 25334 Status: Offline Thanks Meter: 2 | A530F Read Codes via Server failed [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG Jan 2021] Selected model: SM-A530F Software version: 42.10 Checking Login and Password... OK Ballance: 32 crd. You have 32 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A530F Android version: 9 PDA version: A530FXXSGCUA1 CSC version: A530FOXMGCUA1 Phone version: A530FXXSGCUA3 Product code: SM2A530FZKASER CSC country code: Russia CSC sales code: SER Carrier ID: PAN Phone SN: R58K80XSK0R IMEI: 355038096733440 HW version: REV0.3 RF cal date: 20180807 Chip name: EXYNOS7885 Modem board: SHANNON327 Security patch: 2021-01-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Waiting ADB device... OK Searching Samsung diag port... detected COM17 Checking diag port... OK Searching Samsung modem... detected COM16 Searching server... OK Checking server answer... modem not supported Done with Samsung Tool PRO v.42.10 Operation: Read Codes via Server [DIAG Jan 2021] Selected model: SM-A530F Software version: 42.10 Checking Login and Password... OK Ballance: 32 crd. You have 32 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A530F Android version: 9 PDA version: A530FXXSGCUA1 CSC version: A530FOXMGCUA1 Phone version: A530FXXSGCUA1 Product code: SM2A530FZKASER CSC country code: Russia CSC sales code: SER Carrier ID: PAN Phone SN: R58K80XSK0R IMEI: 355038096733440 HW version: REV0.3 RF cal date: 20180807 Chip name: EXYNOS7885 Modem board: SHANNON327 Security patch: 2021-01-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Waiting ADB device... OK Searching Samsung diag port... detected COM17 Checking diag port... OK Searching Samsung modem... detected COM16 Searching server... OK Checking server answer... modem required There is no information about this firmware on the server. Done with Samsung Tool PRO v.42.10 |
