10-03-2009, 14:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: On Earth
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | How Can I remove my password for Samsung S5603 ? |
The Following User Says Thank You to caremobiles For This Useful Post: |
10-03-2009, 15:02 | #3 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Yes I know but it was not connect to our software because when I power on the handset it was ask phone lock.Thats why it was not connect.Is their any solution to connect this handset? |
10-03-2009, 15:25 | #4 (permalink) |
No Life Poster Join Date: Apr 2007
Member: 485779 Status: Offline Thanks Meter: 135 | *#782872# or *#9998*342# then press 9 and then press 6 it's show u the usb option then install the driver Hope it will work for u.................................. ok Thanks |
10-03-2009, 15:41 | #5 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Thanks For your reply friend.But its use less for me because when I power on handset it will shows enter the phone code.I did not insert the simcard also.It asks same. |
10-03-2009, 15:47 | #6 (permalink) |
Member: 332724 Status: Offline Sonork: 100.1605077 Thanks Meter: 231 | Finally I successfully flashed the handset.It was just doing in wrong process problem.Any way Thanks for your replies every body.And Thanks to Z3X Team and speacially Thanks to our product king Mr.Blang. Here is the Log: Checking ports... ok Searching Samsung USB interface... detected (COM21) Checking mobile state... normal Model: GT-S5603 SW: S5603DDIF1 IMEI: 3542770xxxxxxxx Searching Samsung USB interface... not found Searching Qualcomm Diagnostics interface... not found Searching Samsung USB interface... detected (COM21) Checking mobile state... flash Searching phone at COM interface... unable to find phone COM interface required Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Checking ports... ok Searching Samsung USB interface... detected (COM21) Checking mobile state... flash Request error! Searching Samsung USB interface... detected (COM21) Checking mobile state... flash Sending file 1 of 4... sended Sending file 2 of 4... sended Sending file 3 of 4... sended Sending last file... sended Flashing done (time - 12:09:14 AM) Last edited by caremobiles; 10-03-2009 at 15:48. Reason: I forgot to upload log. |
;pls how can i remove user code for htc o2 arte 200 | TALIAT | HTC & PDA WM( With Touchscreen) | 6 | 03-13-2010 19:17 |
how can i know my password.... | jimmyyew1981 | Cruiser Suite | 1 | 01-04-2010 00:54 |
How Can I Open Phone Lock Code Samsung S5603 | rajinder1978 | UST Pro II | 5 | 11-03-2009 01:12 |
hOW cAN i rEMOVE uSER cODE fOR I560V? | .:==di@bila==:. | Samsung Flashers, Software, Firmware. | 0 | 05-16-2009 14:55 |
How can I identify the cable for SAMSUNG mobile? | hmanhha | Samsung Flashers, Software, Firmware. | 4 | 06-30-2003 17:17 |
