07-04-2020, 17:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Zimbabwe
Member: 2524486 Status: Offline Thanks Meter: 112 | How to solve samsung G925F error when rep BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Write CERT Selected model: SM-G925F Software version: 40.7 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 5.0.2 PDA version: G925FXXU1AOD4 CSC version: Phone version: G925FXXU1AOCZ Product code: SM-G925FZKEXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RF8G41S5W8Z IMEI: HW version: MP 0.600 RF cal date: 20150422 Chip name: EXYNOS7420 Modem board: SHANNON333 Boot Warranty bit: 1 SIM State: ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... error (7.5.2) Done with Samsung Tool PRO v.40.7 |
