09-17-2009, 13:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Hungary Age: 46
Member: 40263 Status: Offline Thanks Meter: 14 | I8910 unlock Help!! [Solved] Unlocking... This version FW not supported () Error (Cant Read Security data (0) -------------------------------- Reading Codes... This version FW not supported () -------------------------------- Error Reset User Lock -------------------------------- No answer from phone Unlocking... This version FW not supported () Error (Cant Read Security data (0) -------------------------------- No answer from phone -------------------------------- Reading Codes... This version FW not supported () which FW version supported?? Thx |
09-17-2009, 14:19 | #4 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | what not worked? That code? of course you can not use that code, cause is for my phone. I put picture o see firmware version from a phone that worked. this is info you need I8910BVIE7 |
09-17-2009, 14:35 | #6 (permalink) |
Member: 40263 Status: Offline Thanks Meter: 14 | I do not know how good the code. I8910BVIE7 software for it but not good READ NEWS FOR DETAILS! -------------------------------- No answer from phone -------------------------------- No answer from phone -------------------------------- Phone S/N: Power on? Power off? |
09-17-2009, 14:51 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 173741 Status: Offline Thanks Meter: 986 | Use rj45 in z3x box : I8910 pinout 1 2 3 4 5 6 7 8 9 10 2 Tx 3 Rx 5 GND 2 pin phone to 3 pin RJ45 3 pin phone to 2 pin RJ45 5 pin phone to 7,8 pin RJ45 HOW INPUT CODE: enter in phone #pw+code+1# Pinout under batery like Samsung G810 |
The Following 4 Users Say Thank You to Souhail For This Useful Post: |
09-17-2009, 15:01 | #8 (permalink) |
Freak Poster Join Date: May 2009
Member: 1024080 Status: Offline Thanks Meter: 90 | now it's very clear thank you best freind g810 easy to unlcok with only rx ,tx ,gnd and i put battery on the cable no need +5v |
The Following User Says Thank You to .:Solo:. For This Useful Post: |
09-17-2009, 21:09 | #10 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Moldova
Member: 106887 Status: Offline Thanks Meter: 48 | hey guys can someone say phone must be on or off? because i've tried the pinout and i thinck that the cable is ok but this is what i get READ NEWS FOR DETAILS! -------------------------------- No answer from phone -------------------------------- No answer from phone -------------------------------- always like this! |
09-17-2009, 21:18 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
no connecting between phone pins -wires -rj45box - com port - software check com port, check pinouts, | |
The Following User Says Thank You to blang For This Useful Post: |
nokia n85 unlocking help [SOLVED] | tecnofoto | Cyclonebox | 2 | 02-15-2010 13:49 |
I8910 unlock error ... try to update but..??? need help. | Sudan-Mobiles | UST Pro II | 3 | 01-19-2010 08:52 |
Samsung s5230 ,, how can unlock,,,help,, [Solved] | diva2812 | Z3X-Team Products | 2 | 09-24-2009 22:18 |
Storm 9500 Unlock Help [SOLVED] | ivan_adrian | FuriousGold | 6 | 08-27-2009 17:23 |
blackberry 9000 unlocking help [Solved] | thethi | FuriousGold | 6 | 08-23-2009 08:48 |
