01-25-2017, 15:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | j200h unlock sucessfully UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J200F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZDDKSA Phone version: J200FXXU2API1 PDA version: J200FXXU2APJ1 CSC version: J200FOJV2APJ1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RV8J10DMHMR Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20170106 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 25 A0 0C E0 0D 90 12 4A FD 00 BE B1 F6 11 93 FC Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.7 |
