01-12-2018, 20:08 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jamaica
Member: 1000658 Status: Offline Thanks Meter: 69 | j327t1 still locked after success please help UNLOCK INSTRUCTIONS: Warning! Knox warranty must be active (0x00)! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Type *#0808# and select 'DM + MODEM + ADB' (or 'DM + ACM + ADB'). 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Unlock Selected model: SM-J327T1 Software version: 30.4 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J327T1 Android version: 7.0 Product code: SM2J327TZKATMK Phone version: J327T1UVU1AQCB PDA version: J327T1UVU1AQCB CSC version: J327T1TMK1AQCB CSC country code: USA CSC sales code: TMK HW version: REV0.1 Phone SN: R28J72Z8TBV Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-03-01 RF cal date: 20170724 IMEI: 355604085804029 Searching Samsung diag port... detected COM301 Reading phone info... OK CP version: J327T1UVU1AQCB CP build: Mar 23 2017 16:54:01 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... Please, allow USB debugging on phone... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.4 |
01-12-2018, 21:15 | #2 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Cuba Age: 38
Member: 983297 Status: Offline Thanks Meter: 61 | Hard reset the phone and repeat the proccess , from the same IP/SN/and user not discount credit !!!! OK is going to say that 10 credit requiere but not discount Lucky!!! |
