04-22-2018, 10:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: pakistan Age: 35
Member: 1164608 Status: Offline Sonork: 100.1650273 Thanks Meter: 105 | j510f system file error Selected model: SM-J510F Software version: 31.3 File analysis... OK Total file size: 0xB46425DC (2886 Mb) Searching USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending hyp.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... error Done with Samsung Tool PRO v.31.3 tried 3 files but still same error J510FXXU2BRB2_J510FOJV2BRB2_PAK J510FXXU2AQG4_J510FOJV2AQG3_PAK J510FXXU2BRB2_J510FOJV2BRB2_KSA |
04-22-2018, 17:44 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: sharjah, united arab emirates Age: 31
Member: 2149733 Status: Offline Thanks Meter: 83 | bro u can try other pc and u can try another usb cable or port use only single usb at the moment check and post results if still same error what was the problem before.... |
04-23-2018, 11:58 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Try this firmware with PIT file: J510FXXU2BRB2 - 7.1.1 -XSG(United Arab Emirates) - Multi Firmware + PIT.zip use Odin3 v3.13.1 Odin3_v3.13.1.zip |
The Following User Says Thank You to voltran2008 For This Useful Post: |
