Old 03-16-2018, 21:53   #226 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
ok no need to ,there's poblem with v9.48
LG 2-3G Tool v9.47
supported models: 1555
Mode: Normal
Model: LGH830AT
Build version: Nov 7 201613:10:56Oct 19 201604:00:00LGH830AT
SW Version: MPSS.TH.2.0.c1.4-00042-M8996FAAAANAZM-1.74312.1
IMEI: 35nnnnnnnnnnh Address: 00:00:00:00:00:00
Phone Code:
Elapsed: 1 secs. --> (v9.47)
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Searching modem interface... found COM8
Reading data from phone... OK
IMEI: 35nnnnnnnnnnnnnn
Checking root rights... OK
Writing zTool... OK
SW Version: H83020a
Initialization zTool... (this can take 1-2 minutes) OK
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Unlocking done
Elapsed: 153 secs. --> (v9.47)
The Following User Says Thank You to bhiret For This Useful Post:
Old 03-16-2018, 22:02   #227 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
LG 2-3G Tool v9.47
Mode: Normal
Model: LGH830AT
Phone Code:
Ballance: 30 crd.
Writing zTool... OK
SW Version: H83020a
Calculating... OK
Unlocking done
This isn't problem in 9.48. Some mistake from transfer data from phone to PC.
Old 03-16-2018, 22:27   #228 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
ok im satisfied anwyay ,good work
Old 03-17-2018, 02:44   #229 (permalink)
GuilleC_PMA's Avatar
Member: 86124
Sonork: 100.1604943
Thanks Meter: 111
Model: LGMP260A
Build version: Feb 8 201818:23:53May 27 201713:00:00LGMP260A
SW Version: MPSS.JO.2.0.c1.2-00031-8937_GENNS_PACK-1
Any have root for this phone please send me link
Old 03-17-2018, 07:01   #230 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
Mode: Normal
Model: LGK330AT
Build version: Nov 1 201719:15:55Nov 17 201500:00:00LGK330AT
SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1
IMEI: xxxxxxxxxxxxxxx
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
Elapsed: 1 secs. --> (v9.48)
Ballance: 30 crd.
Searching modem interface... found COM1040
Writing zTool... OK
SW Version: K33010n
Calculating... OK
Unlocking done
Elapsed: 174 secs. --> (v9.48)
The Following User Says Thank You to jmr For This Useful Post:
Old 03-17-2018, 08:02   #231 (permalink)
Member: 2659717
Thanks Meter: 487
Root file
Pls share root file or method
Old 03-17-2018, 16:00   #232 (permalink)
Member: 86124
Sonork: 100.1604943
Thanks Meter: 111
MP260 please need root
Old 03-17-2018, 18:04   #233 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
https://www.androidweblog.com/root-l...twrp-recovery/
Old 03-17-2018, 20:51   #234 (permalink)
Member: 2347074
Thanks Meter: 30
LG TP450 not supported :eek:
I am running the latest LG Tool v9.48 and LGTP450 is not supported. As a matter of fact, the UNLOCK button is grey out. I cannot downgrade back to v9.45 cuz the credits won't login. Maybe this is a mistake team. Do something please
Old 03-17-2018, 20:58   #235 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Sorry, but we remove support TP450 because try on few versions and LG close bug how we use. You can select any TMB phone(ms345 for example) and try unlock. If software not unlock you not lost credits.
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 03-17-2018, 21:50   #236 (permalink)
Member: 2720830
Thanks Meter: 29
LG MS 631 unlocked, I had many problems with the unlock process when z3x asked for root permission tne phone never showed de SUPERSU I had to make the unlock in other PC
Modo: Normal
17/03/2018 19:14:16: modelo MS631
17/03/2018 19:14:16: Versión de la compilación: Feb 3 201719:45:27Dec 23 201522:00:00EAAAANVZ
17/03/2018 19:14:16: version de SoftWare MPSS.DPM.2.0.c11-00047-M8936FAAAANUZM-1.38601.2
17/03/2018 19:14:16: IMEI: 35838806xxxxxxx
17/03/2018 19:14:17: Dirección del BlueTooth: 00:00:00:00:00:00
17/03/2018 19:14:17: Código del teléfono: por defecto
17/03/2018 19:14:17: Transcurrido 1 segundos --> (v9.48)
17/03/2018 19:14:17: Checking Login and Password...
17/03/2018 19:15:47: OK
17/03/2018 19:15:47: Ballance:
17/03/2018 19:15:47: 40 crd.
17/03/2018 19:15:52: You have 40 credit(s) left. This operation takes 10 credits.Continuar?
17/03/2018 19:15:52: Yes
17/03/2018 19:15:59: Searching modem interface...
17/03/2018 19:15:59: found COM35
17/03/2018 19:15:59: Reading data from phone...
17/03/2018 19:15:59: OK
17/03/2018 19:15:59: IMEI: 35838806xxxxxxx
17/03/2018 19:19:05: Checking root rights...
after 5 times
Modo: Normal
17/03/2018 20:19:08: modelo MS631
17/03/2018 20:19:08: Versión de la compilación: Feb 3 201719:45:27Dec 23 201522:00:00EAAAANVZ
17/03/2018 20:19:08: version de SoftWare MPSS.DPM.2.0.c11-00047-M8936FAAAANUZM-1.38601.2
17/03/2018 20:19:08: IMEI: 35838806xxxxxxx
17/03/2018 20:19:08: Dirección del BlueTooth: 00:00:00:00:00:00
17/03/2018 20:19:08: Código del teléfono: por defecto
17/03/2018 20:19:08: Transcurrido 1 segundos --> (v9.48)
17/03/2018 20:19:08: Checking Login and Password...
17/03/2018 20:20:26: OK
17/03/2018 20:20:26: Ballance:
17/03/2018 20:20:26: 40 crd.
17/03/2018 20:20:29: You have 40 credit(s) left. This operation takes 10 credits.Continuar?
17/03/2018 20:20:29: Yes
17/03/2018 20:20:30: Searching modem interface...
17/03/2018 20:20:30: found COM35
17/03/2018 20:20:30: Reading data from phone...
17/03/2018 20:20:30: OK
17/03/2018 20:20:30: IMEI: 35838806xxxxxxx
17/03/2018 20:20:34: Checking root rights...
17/03/2018 20:20:34: OK
17/03/2018 20:20:36: Writing zTool...
17/03/2018 20:20:36: OK
17/03/2018 20:20:36: SW Version: MS63120l
17/03/2018 20:20:36: Initialization zTool... (this can take 1-2 minutes)
17/03/2018 20:21:52: OK
17/03/2018 20:21:52: Reading data from phone...
17/03/2018 20:22:13: OK
17/03/2018 20:22:13: Calculating...
17/03/2018 20:22:15: OK
17/03/2018 20:22:15: Searching server...
17/03/2018 20:23:25: OK
17/03/2018 20:23:25: Waiting for server answer...
17/03/2018 20:23:26: OK
17/03/2018 20:23:26: Initialization zTool... (this can take 1-2 minutes)
17/03/2018 20:23:27: OK
17/03/2018 20:23:27: Reading data from phone...
17/03/2018 20:23:28: OK
17/03/2018 20:23:28: Unlocking done
thanks *** I didnt lose more than 10 credits
Old 03-17-2018, 21:51   #237 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Modo: Normal
17/03/2018 19:14:16: modelo EAAAANVZ
after 5 times
Modo: Normal
17/03/2018 20:19:08: modelo EAAAANVZ
17/03/2018 20:20:30: IMEI: 358388067271475
Maybe some conflict with adb or phone driver.
Old 03-18-2018, 01:13   #238 (permalink)
Member: 2582877
Thanks Meter: 15
I flash kdz > M320TV10d_00_OPEN_SCA_DS_OP_0718.kdz, in black screen for my LG k10 power, M320TV, for remove FRP, the phone is work, solo black screen
The Following User Says Thank You to ericknio For This Useful Post:
Old 03-18-2018, 14:48   #239 (permalink)
Member: 1334744
Sonork: 1617739:dammy21
Thanks Meter: 14
Add root file on shell especially lg h631 root step thanks
Old 03-18-2018, 22:17   #240 (permalink)
Member: 2707718
ok
i´m reading that you bring the steps for root, that works for me,
by the way how root for lg aristo
Page generated in 0.26368 seconds with 8 queries
