03-14-2018, 18:01 | #199 (permalink) | |||
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Probably your connection is going through the "Castro Spy Network" (lol), so use a secure (https) proxy or VPN to try to bypass it (avoid packet sniffing). By the way your speedtest shows less than 2Mbps up/down which is kind of slow, it works better at above 5Mbps with low latency (<100ms). Quote:
Good luck! Comport_Setter_v0.8.0.37.ZIP https://androidfilehost.com/?fid=745425885120755601 Last edited by BillA; 03-14-2018 at 18:11. | |||
The Following User Says Thank You to BillA For This Useful Post: |
03-14-2018, 18:33 | #200 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
Code: Reply from xx: bytes=32 time=782ms TTL=44 Reply from xx: bytes=32 time=1613ms TTL=44 Reply from xx: bytes=32 time=871ms TTL=44 Reply from xx: bytes=32 time=247ms TTL=44 About port this phone after wipe and hasn't some data. But we fix this in 9.48. -- | |
03-15-2018, 04:25 | #204 (permalink) |
Major Poster Join Date: Aug 2008 Location: MX
Member: 835563 Status: Offline Thanks Meter: 22 | LG k550 not unlocked Hello friend!! yesterday i made 2 unlocks for LG k550 but one of they does not get unlock here is the log Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM111 Reading data from phone... OK IMEI: *******71936685 Checking root rights... OK Writing zTool... OK SW Version: K55020a Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 196 secs. --> (v9.48) You can check my credits logs to see im telling the true!!, can you help me!! |
03-15-2018, 18:33 | #205 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Working like a charm... :P Code: Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM13 Reading data from phone... OK IMEI: 35239207xxxxxxx Checking root rights... OK Writing zTool... OK SW Version: H81120q Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Initialization zTool... (this can take 1-2 minutes) OK Reading data from phone... OK Unlocking done Elapsed: 158 secs. --> (v9.48) |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
03-15-2018, 19:55 | #206 (permalink) | |
The Following User Says Thank You to andrew_tm For This Useful Post: |
03-15-2018, 20:24 | #208 (permalink) | |
Read this thread: http://forum.gsmhosting.com/vbb/f453...rvice-2360620/ -- | |
03-15-2018, 20:42 | #209 (permalink) | |
Member: 835563 Status: Offline Thanks Meter: 22 | Quote:
03-15-2018, 20:44 | #210 (permalink) | |
Read thread how I share for you. Before write another QCN make Security Backup. P.S. There is great button "New thread" where you can post your log and about your problem. -- | |
