03-13-2018, 10:02 | #166 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
The Following User Says Thank You to andrew_tm For This Useful Post: |
03-13-2018, 10:52 | #167 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Montenegro Podgorica Age: 46
Member: 216844 Status: Offline Thanks Meter: 30 | LG 2-3G Tool v9.47 supported models: 1555 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 2 secs. --> (v9.47) |
The Following User Says Thank You to Selmir For This Useful Post: |
03-13-2018, 12:45 | #169 (permalink) | |
Send team viewer id and pass to me in PM. We check your problem. | |
03-13-2018, 13:34 | #171 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 973429 Status: Offline Sonork: 100.1586829 Thanks Meter: 48 | NICE UPDATE BUTT MAIN ISSUE HOW DID SAFELY ROOT BECOUSE SOME TIME DURING ROOT LG PHONES DEAD AND GO IN 9008_BULK mode NEED SAFE ROOT FOR H872 (TMOBILE USA) ANY ONE HAVE PLZ SHARE HERE IS FULL DETAIL : -- Found -- MODAL : LG-H872 -- MANUFUCTURER : lge -- ANDROID VERSION : 7.0 -- CPU : arm64-v8a -- MMC STORAGE : 0 Bytes -- HARDWARE : lucye -- BOARD : msm8996 -- BOOTLODER : unknown -- USB CONFIG : mtp,adb -- USER : jenkins -- BASEBAND : MPSS.TH.2.0.1.c3.1-00018-M8996FAAAANAZ -- DISPLAY ID : NRD90U -- BUILD ID : NRD90U -- SIM STAT. : NETWORK_LOCKED -- BUILD DATE : Mon Dec 18 15:35:41 KST 2017 -- BUILD TAGS : release-keys -- NETWORK TYPE : Unknown -- SIM OPERATOR : -- LCD DENSITY : 640 -- IMEI 1 : -- IMEI 2 : service: iphonesubinfo2 -- ROOT STATUS -- Superuser.Apk : Not Installed -- BusyBox : Not Installed -- Su Binararies : Null -- Root Status : NOT ROOTED |
03-13-2018, 13:48 | #172 (permalink) | ||
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
At least please include the exact model and firmware version so developer can investigate it. Quote:
Most likely you have overwritten the booloader with recovery. You can brick easily, and it's very difficult to revive it. I agree that developer should think about including rooting method in the app, however I know it's not easy because each model is different (no one click here). | ||
The Following 2 Users Say Thank You to BillA For This Useful Post: |
03-13-2018, 15:32 | #173 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2707718 Status: Offline Thanks Meter: 1 | HI i´m agree. the developer MUST add a safe root method, WE ALL know how fragile are the LG system, i had some LG phones with boot damaged when i tried to root, even when tried to flash with the same version. please make any autoroot or sort of it, thanks. ANYWAY, great job. |
03-13-2018, 15:34 | #174 (permalink) | |
03-13-2018, 17:20 | #175 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Sénégal Dakar
Member: 217769 Status: Offline Thanks Meter: 24 | Bug ????? Mode: Normal Model: LGK330AT Build version: Jul 22 201611:52:52Nov 17 201500:00:00LGK330AT SW Version: MPSS.JO.1.0.c5.7-00006-M8909EAAAANVZM-1 IMEI: 352569081XXXXXX0:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.48) Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Searching modem interface... found COM51 Reading data from phone... OK IMEI: 352569081XXXXXX Adb device not found Elapsed: 11 secs. --> (v9.48) |
03-13-2018, 17:41 | #176 (permalink) | |
- check Adb driver - enter in console: adb kill-server - close other software(maybe some software use ADB) -- | |
03-13-2018, 19:30 | #180 (permalink) |
No Life Poster Join Date: Jul 2006 Location: SCN Movil Centro
Member: 321176 Status: Offline Sonork: 100.1640958 Thanks Meter: 62 | ISP Speed There is Speed test on my ISP please check is enough or not. https://i.imgur.com/VrLhbTT.jpg |
