07-08-2015, 19:18 | #49 (permalink) |
Freak Poster Join Date: Sep 2005 Location: USA Age: 39
Member: 180148 Status: Offline Thanks Meter: 48 | Hi , i try new options but won't work for me. Do some body know exactly the steps ? Thank you !!! For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Mode: Normal Model: EAAAANVZ Build version: Apr 18 201510:53:45Mar 10 201506:00:00EAAAANVZ SW Version: MPSS.DPM.2.0.c11-00014-M8936FAAAANUZM-1 IMEI: 35838**********-3 BlueTooth Address: 69:6C:6F:70:2F:00 Phone Code: default Elapsed: 0 secs. --> (v7.8) Repair IMEI... Check adb server status... OK Found 1 device(s) Device name: LGMS631 Firmware version: Android release: 5.0.2 Platform: msm8916 Root status: OK! Checking phone at COM142 Detected ID: 00000FFE (MSM8916) SW Version: MPSS.DPM.2.0.c11-00014-M8936FAAAANUZM-1 Reading ESN... OK Read SPC... Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: Not exist security block! Elapsed: 221 secs. --> (v7.8) |
07-08-2015, 20:06 | #51 (permalink) |
Member: 180148 Status: Offline Thanks Meter: 48 | THANKS - andrew_tm Andrew fixed my phone. We choose tick "manual choice of model" 2. choice model H815, 3. repair IMEI than 4. fix IMEI 0... fix reboot and phone is good now first make sure you make back up on security ZONE Thanks Andrew !! |
07-09-2015, 04:15 | #52 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | LG 2-3G Tool v7.8 supported models: 1015 For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Port already opened! Elapsed: 0 secs. --> (v7.8) For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Mode: Normal Model: P655H10b Build version: Jan 7 201410:58:21Jan 7 201410:58:21P655H10b SW Version: P655H10b IMEI: 35893905076952-7 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 1 secs. --> (v7.8) For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Mode: Normal Model: P655H10b Build version: Jan 7 201410:58:21Jan 7 201410:58:21P655H10b SW Version: P655H10b IMEI: 35893905076952-7 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v7.8) Checking phone at COM175 Detected ID: 00000FEC (MSM8930) SW Version: P655H10b Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Elapsed: 184 secs. --> (v7.8) For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Mode: Normal Model: P655H10b Build version: Jan 7 201410:58:21Jan 7 201410:58:21P655H10b SW Version: P655H10b IMEI: 35893905076952-7 BlueTooth Address: 2C:00:00:00:02:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v7.8) NV read... NV save:..\backup\P659_358939050769527_08072015_21471 7.cnv Elapsed: 174 secs. --> (v7.8) |
07-09-2015, 04:39 | #53 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | For enable DIAG port in Android 5.x use this instruction: 277634#*# -> Port check Test -> set Enabled. Reconnect device. Mode: Normal Model: P655H10b Build version: Jan 7 201410:58:21Jan 7 201410:58:21P655H10b SW Version: P655H10b IMEI: 35893905076952-7 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v7.8) Repair IMEI... Check adb server status... Try kill add server... ERROR Found 1 device(s) Device name: LG-P655H Firmware version: Android release: 4.1.2 Platform: msm8960 Root status: OK! Checking phone at COM175 Detected ID: 00000FEC (MSM8930) SW Version: P655H10b Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: ---------++------------ ---------++------------ Backup security zone... Sec zone saved: ..\Backup\P659_358939050769527_08072015_223517.lgs b1 Writing security zone... Reboot phone Phone detected! Reading QCN file... OK Checking phone at COM175 Detected ID: 00000FEC (MSM8930) SW Version: P655H10b Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Repair IMEI1... Write IMEI 1 OK Repair done! Elapsed: 372 secs. --> (v7.8) choise manual model LG P659 and unlock or repair |
07-10-2015, 19:53 | #57 (permalink) |
Member: 180148 Status: Offline Thanks Meter: 48 | Dont put H819 to MS631 you will brick the phone i bricked one flash stopped on 99% than when remove battery only Black screen. if some body have idea how can fix it PLS share. I see only Qualcomme USB diagnostic port 9008. Thank you ! |
07-10-2015, 19:55 | #58 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
For repair 9008 contact to NoNamer. -- | |
The Following User Says Thank You to andrew_tm For This Useful Post: |
