12-10-2009, 11:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | LG CU500 Cingular Logo Only failed to flash I want to flash it using Z3x but failed upported models: 74 andrew_tm 2009(c) Reading file as CU500... Ok Original Flash File: CU500-V10d-JAN-05-2007-CW-US Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 21 secs. Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 21 secs. Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 21 secs. Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 21 secs. Start Flash... Modem Write Start... Reading timeout, check cable Error Code: send partition table Error send partition table Modem file flash error! Elapsed: 109 secs. Already Emergency Download mode..............whats wrong???????? Last edited by ASHRIFF; 12-10-2009 at 11:07. |
The Following User Says Thank You to ASHRIFF For This Useful Post: |
12-10-2009, 11:16 | #3 (permalink) |
Member: 328416 Status: Offline Thanks Meter: 42 | Mode: Emergency Model: CU500 Elapsed: 0 secs. Start Flash... Modem Write Start... Reading timeout, check cable Error Code: send partition table Error send partition table Modem file flash error! Elapsed: 109 secs. |
12-10-2009, 11:17 | #4 (permalink) |
12-10-2009, 13:31 | #9 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | v.1.7.1 supported models: 74 andrew_tm 2009(c) Mode: Emergency Model: CU500 Elapsed: 0 secs. Reading file as CU500... Ok Original Flash File: CU500-V10d-JAN-05-2007-CW-US Mode: Emergency Model: CU500 Elapsed: 0 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 870 secs. Mode: Normal Model: CU500 Build version: Jan 05 200711:01:31Aug 03 200613:00:00CU500 SW Version: CU500-MSM32701001-V10d-Jan-05-2007-CW-US IMEI: 12345678901234-3 BlueTooth Address: 00:19:A1:E4:7D:7A Flash Name: toshiba_ty90009c00sogg Flash Info: 0898/0020/0200 Elapsed: 0 secs. Loading internal NVM file... NV File Version: 1 NV File Model: CU500 NV Records: 667 Write NV... Phone reboot! Elapsed: 10 secs. Use normal usb cable -- andrew_tm 2009 |
LG KM900 failed to flash | yzf | VygisToolbox | 7 | 06-21-2010 21:28 |
LG KF900 ***** logo done via usb flashing..!!! | newfoundghori | VygisToolbox | 1 | 11-11-2009 03:05 |
lg cu500 cingular | salman_4_ever | LG | 3 | 12-22-2008 20:40 |
siemens st55 logo only..how to repair | kevin182029 | Infinity-Box | 5 | 09-05-2008 11:15 |
CECT Q380 logo only..how to? | kevin182029 | Infinity-Box | 1 | 08-30-2008 10:55 |
