03-21-2016, 11:19 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | LG G4 H818N logo only after flash same problem supported models: 1118 Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v9.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v9.1) Check Android Lollipop... Stage #1 Port already opened! Port already opened! Elapsed: 0 secs. --> (v9.1) Check Android Lollipop... Stage #1 Stage #2 OK Stage #3 OK Android Lollipop detected Enable DIAG cmd in Lollipop... Check adb server status... Try kill add server... ERROR Device not found! Elapsed: 26 secs. --> (v9.1) Check Android Lollipop... Stage #1 ERROR Stage #2 Reading timeout, check cable Error Code: Error read answer! Read info error: 1 Port already opened! Elapsed: 67 secs. --> (v9.1) Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Enable DIAG cmd in Lollipop... Check adb server status... OK Device not found! Elapsed: 20 secs. --> (v9.1) Check Android Lollipop... Stage #1 Stage #2 OK Stage #3 OK Android Lollipop detected Mode: Emergency Model: H818N Elapsed: 35 secs. --> (v9.1) Phone mode is DOWNLOAD Start flashing. LAF: 01000001 Open KDZ File : C:\Users\goverdhan\Desktop\H818N _10F India\H818N _10F India .kdz Model : LG-H818 SwVersion : LGH818AT-00-V10f-GLOBAL-COM-SEP-04-2015+0 BuildTime : 0000-00-00 00:00:00 Total Files : 68 Model name: LG-H818N Software verion: H81810l IMEI: 351775070213436 Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. Start indirect download mode. Sending image... LAF: 01000001 Verifying image... Checking image... Flashing image... Done. Elapsed: 334 secs. --> (v9.1) |
03-21-2016, 14:12 | #5 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Check in options: + flash in direct mode + erase user data after flash If after flash again same problem try up firmware version or check hardware. -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
03-21-2016, 17:19 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Lg G4 H815,come to me,not boot up,only logo,customer try to update with custom marshmallow rom from xda. Tried with z3x both kdz and tot file,but with kdz flash complete and not boot up,with tot do not even start flashing.Tried all version of z3x,8.7 to 9.1,all the same.Finally I used factory LGUP software with tot firmware from z3x support and H815 is alive again :-). Code: 18.3.2016 17:39:30: LG 2-3G Tool v9.1 18.3.2016 17:39:30: supported models: 1118 18.3.2016 17:39:30: 18.3.2016 17:55:59: Check Android Lollipop... 18.3.2016 17:55:59: Stage #1 18.3.2016 17:56:01: ERROR 18.3.2016 17:56:01: Stage #2 18.3.2016 17:57:08: Reading timeout, check cable 18.3.2016 17:57:08: Error Code: Error read answer! 18.3.2016 17:57:08: Read info error: 1 18.3.2016 17:57:08: Port already opened! 18.3.2016 17:57:08: Elapsed: 70 secs. --> (v9.1) 18.3.2016 17:57:08: 18.3.2016 17:57:42: Check Android Lollipop... 18.3.2016 17:57:42: Stage #1 18.3.2016 17:57:43: Stage #2 18.3.2016 17:57:44: OK 18.3.2016 17:57:44: Stage #3 18.3.2016 17:57:45: OK 18.3.2016 17:57:46: Mode: Emergency 18.3.2016 17:57:47: Model: H815 18.3.2016 17:57:47: Elapsed: 5 secs. --> (v9.1) 18.3.2016 17:57:47: 18.3.2016 17:57:47: Phone mode is 18.3.2016 17:57:48: DOWNLOAD 18.3.2016 17:57:48: Start flashing. 18.3.2016 17:57:48: LAF: 01000001 18.3.2016 17:57:48: Open KDZ File : E:\New\H815_20A_00\H815_20A_00.kdz 18.3.2016 17:57:48: Model : LG-H815 18.3.2016 17:57:48: SwVersion : LGH815AT-00-V20a-GLOBAL-COM-OCT-21-2015+0 18.3.2016 17:57:49: BuildTime : 0000-00-00 00:00:00 18.3.2016 17:57:49: Total Files : 68 18.3.2016 17:57:50: Model name: LG-H815 18.3.2016 17:57:50: Software verion: H81520d 18.3.2016 17:57:50: IMEI: 359872068735835 18.3.2016 17:57:51: Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. 18.3.2016 17:57:51: Start indirect download mode. 18.3.2016 17:57:51: Sending image... 18.3.2016 17:57:51: LAF: 01000001 18.3.2016 18:01:51: Verifying image... 18.3.2016 18:01:51: Checking image... 18.3.2016 18:02:31: Flashing image... 18.3.2016 18:02:31: Done. 18.3.2016 18:02:32: Elapsed: 284 secs. --> (v9.1) 18.3.2016 18:02:32: 18.3.2016 18:07:40: Check Android Lollipop... 18.3.2016 18:07:40: Stage #1 18.3.2016 18:07:42: ERROR 18.3.2016 18:07:42: Stage #2 18.3.2016 18:07:42: Read info error: 1 18.3.2016 18:07:45: Reading timeout, check cable 18.3.2016 18:07:45: Error Code: ReadInfo,1,1 18.3.2016 18:07:45: Elapsed: 5 secs. --> (v9.1) 18.3.2016 18:07:45: 18.3.2016 18:13:53: Check Android Lollipop... 18.3.2016 18:13:53: Stage #1 18.3.2016 18:13:54: Stage #2 18.3.2016 18:13:55: OK 18.3.2016 18:13:55: Stage #3 18.3.2016 18:13:56: OK 18.3.2016 18:13:57: Mode: Emergency 18.3.2016 18:13:58: Model: H815 18.3.2016 18:13:58: Elapsed: 5 secs. --> (v9.1) 18.3.2016 18:13:58: 18.3.2016 18:13:58: Phone mode is 18.3.2016 18:13:59: DOWNLOAD 18.3.2016 18:13:59: Start flashing. 18.3.2016 18:13:59: LAF: 01000001 18.3.2016 18:13:59: Open TOT File : E:\New\TOT_LGH815AT-00-V10h-GLOBAL-COM-AUG-25-2015+0\LGH815AT-00-V10h-GLOBAL-COM-AUG-25-2015+0.tot 18.3.2016 18:13:59: TOT Parser error: could not read TOT header. 18.3.2016 18:13:59: Flashing error. 18.3.2016 18:13:59: Elapsed: 1 secs. --> (v9.1) 18.3.2016 18:13:59: |
The Following User Says Thank You to galijus For This Useful Post: |
