11-23-2010, 07:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | LG km900 version mismatch Code: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Found firmware version marker... Found firmware version marker... Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in UART Mode (COM11 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KM900_autobackup_23112010_133530.eep Analising EEPROM... Unlock codes: NCK[0]: 511029xxxxxxxxxx (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds Flashing of this region are not supported! Detecting FLS File version... Preprocessing FLS File.... Starting Flash Applet Starting Flash Applet Opening "KM900AT-00-V10f-ARB-XXX-JUN-12-2009+0.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Certificate Failed! TIP: For KM900 and etc. phones use USB flashing mode , if UART fails. Finished in 41 minutes 29 seconds. |
11-23-2010, 09:04 | #2 (permalink) |
Member: 173565 Status: Offline Thanks Meter: 71 | another firmware still the same ? Code: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Found firmware version marker... Found firmware version marker... Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in UART Mode (COM11 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KM900_autobackup_23112010_151530.eep Analising EEPROM... Unlock codes: NCK[0]: 511029xxxxxxxxxx (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds Reading ... Analising EEPROM... Phone IMEI:35215xxxxxxxxxx For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): NCK[0]: 5110299083347549 (LOCKED) NCK[1]: 5110299083347549 (LOCKED) Finished in 2 seconds Repairing EEPROM... Function not avaiable for this model Finished in 0 seconds Detecting FLS File version... Preprocessing FLS File.... Starting Flash Applet Starting Flash Applet Opening "KM900AT-00-V10c-452-XXX-MAY-21-2009+0.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSI:psi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Certificate Failed! TIP: For KM900 and etc. phones use USB flashing mode , if UART fails. Finished in 46 minutes 33 seconds. |
11-23-2010, 09:15 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,595 | Quote:
TIP: For KM900 and etc. phones use USB flashing mode , if UART fails. | |
11-23-2010, 10:05 | #5 (permalink) |
Member: 173565 Status: Offline Thanks Meter: 71 | solved,thanks for tips Code: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Found firmware version marker... Found firmware version marker... Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in UART Mode (COM11 ,921600) Please reconnect battery, press and hold power button... Phone found! (MCU:PMB8868) prebooting... Release power button. Booting... Changing Speed... Reading info... BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KM900_autobackup_23112010_151530.eep Analising EEPROM... Unlock codes: NCK[0]: 511029xxxxxxxxxx (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 3 seconds Reading ... Analising EEPROM... Phone IMEI:35215xxxxxxxxxx For operation finishing,do next : 1. power phone ON with original SIM 2. type 2945#*71001# to enter unlock menu 3. Enter one of this code(s): NCK[0]: 511029xxxxxxxxxxx (LOCKED) NCK[1]: 511029xxxxxxxxxxx (LOCKED) Finished in 2 seconds Repairing EEPROM... Function not avaiable for this model Finished in 0 seconds Detecting FLS File version... Preprocessing FLS File.... Starting Flash Applet Starting Flash Applet Opening "KM900AT-00-V10c-452-XXX-MAY-21-2009+0.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSI:psi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Certificate Failed! TIP: For KM900 and etc. phones use USB flashing mode , if UART fails. Finished in 46 minutes 33 seconds. |
11-23-2010, 10:26 | #7 (permalink) |
Member: 173565 Status: Offline Thanks Meter: 71 | done used usb cable thanks. Code: Welcome to LG Infineon SGOLD3 TOOL v2x by NoName® Models count: 80 Current OS : Windows XP Welcome to Sgold3 Module!! Count supported models - 80 ***Disconnected*** TIP: Please reconnect phone battery / power source. Port list updated! Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in UART Mode (COM10 ,921600) Please reconnect battery, press and hold power button... BOOT Failed ***Disconnected*** TIP: Please reconnect phone battery / power source. Loading module , please wait... PMB8878 Module 1.0a started. SW: Ver 2.2.8.0 Connecting to KM900 in USB Mode... Please connect phone , it must be powered off Booting... \\.\USB1 Phone found! (MCU:SG3_USB) prebooting... Flash ID: 00FF00 *Note in USB mode flash id can be incorrectly read* BOOT Stage Finished , sending authority... Sending SEC pack... Reading ... Backup Saved AS:C:\Program Files\Z3X\LG\LGI_SG3\BACKUP\KM900_autobackup_23112010_163546.eep Analising EEPROM... Unlock codes: NCK[0]: 511029xxxxxxxxxx (LOCKED) TIP: For additional codes , select Read Codes option and click Unlock button Finished in 2 seconds Found firmware version marker... Found firmware version marker... Detecting FLS File version... Preprocessing FLS File.... Starting Flash Applet Starting Flash Applet Opening "KM900AT-00-V10c-452-XXX-MAY-21-2009+0.fls"... Writing FLS:DSP:../../../wou_build/OPERA_EUROPE_OPEN_RELEASE/MPEH_OPERA_EUROPE_OPEN.dsp Sending SEC pack... Done FLS:DSP Writing FLS:STATIC_EEP:MPEH_OPERA_EUROPE_OPEN.eep Sending SEC pack... Done FLS:STATIC_EEP Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Sending SEC pack... Writing FLS:CODE:MPEH_OPERA_EUROPE_OPEN.fls Done FLS:CODE Writing FLS:CUST_DISK:OPERA_EUROPE_OPEN-CUST.dfat Sending SEC pack... Done FLS:CUST_DISK Writing FLS:ROOT_DISK:OPERA_EUROPE_OPEN-ROOT.dfat Sending SEC pack... Done FLS:ROOT_DISK Writing FLS:USER_DISK:OPERA_EUROPE_OPEN-USER.dfat Sending SEC pack... Done FLS:USER_DISK Writing FLS:PSI:psi_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:PSI Writing FLS:SLB:slb_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:SLB Writing FLS:UA:ua_large_block_16_bit_paging.flb Sending SEC pack... Done FLS:UA Writing FLS:AMD_SINGLE:a250_single_image.fls Sending SEC pack... Done! Finished in 19 minutes 41 seconds. |
The Following 2 Users Say Thank You to mccm For This Useful Post: |
01-11-2011, 10:18 | #9 (permalink) |
Freak Poster Join Date: May 2006 Location: Slovakia
Member: 272319 Status: Offline Thanks Meter: 99 | Which usb cable you are using? I was trying some original LG and Z3X KU311 usb cable, but i dont know if there exist more cables with same connector, because when i plug in cable to phone program stops and close. SGOLD3 TOOL v2.2.8.0 |
01-11-2011, 10:42 | #10 (permalink) |
Member: 272319 Status: Offline Thanks Meter: 99 | Now i try to connect direct to a powered usb hub and it strat flashing, maybe something wrond with powering usb port on my pc, causing to close program when protection card smard card reader has low voltage. |
How unlock new nokia5110 version 5.20 ? | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-21-2011 07:45 |
5110 version 5.24 solution | lampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 07:00 |
New 8810 SW version | YaKuMo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-05-1999 11:22 |
How unlock Nokia version 5.20 | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-17-1999 17:35 |
