10-08-2017, 06:24 | #1 (permalink) |
Crazy Poster Join Date: Aug 2014 Location: Philippines
Member: 2245621 Status: Offline Thanks Meter: 6 | Lg m150 unlock failed help Model: LGM150AT Build version: Jan 25 201720:47:20Jan 23 201702:00:00LGM150AT SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 IMEI: 35406308389860-1 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.40) Checking phone at COM81 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 Reading ESN... OK Read SPC... Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Laf cmd error: could not open port. Elapsed: 193 secs. --> (v9.40) please help i enabled port check test but no comports detected by pc so i change "lte data test"; "tethering mode" from android to qmicm then comports detected but this is the result |
10-08-2017, 08:21 | #3 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Install LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe from support and connect phone in Charge Only or MTP mode. Connect phone direct to PC without any USB hub and box. I think you use some hub or connect phone in box port and after reboot software can't open phone port. If this not help make next: 1. Read QCN 2. Put manual phone in Download mode(Vol + and insert USB cable). 3. Make Security Reset. 4. Write QCN. 5. Make IMEI 0 Fix. -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
11-26-2017, 05:59 | #8 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
It's possible that the bootloader is protected by one of those download mode protection apps like "KillSwitch" or "PayJoy" etc, or just the wrong d/l mode driver is loaded (which is most likely). You could also try a P999/910K resistor d/l cable to force it into download mode. Once fully booted into the OS, you'd have to enable "ADB", "Port Check", and "MTP" to expose the diag ports. Last edited by BillA; 11-26-2017 at 06:04. | |
The Following User Says Thank You to BillA For This Useful Post: |
12-02-2017, 21:33 | #9 (permalink) | |
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
12-03-2017, 06:39 | #10 (permalink) |
Member: 92260 Status: Offline Thanks Meter: 843 | No the P999/910K cable will NOT be able to force the normal d/l mode, it will just boot in KillSwitch mode, but the QC EDL cable will boot it in low level d/l mode. Problem is finding the correct bootloader code for that particular chip. Or must make test point connection on the motherboard. Last edited by BillA; 12-03-2017 at 06:44. |
