08-26-2017, 17:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Lg m200n successfully unlocked with z3x here logs Checking phone at COM835 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00008-8937_GENNS_PACK-1 Reading ESN... OK Read SPC... Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Model name: LG-M200n Software verion: M20010f Android verion: 7.0 Target operator: GLOBAL Target country: COM IMEI: 3549650xxxxxx Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\M200N_354965081xxxxxx_26082017_173457.lg sb1 Write security zone... Erase part1... done Erase part2... done Erase part3... done Reboot... Phone detected! Reading QCN file... OK Checking phone at COM835 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00008-8937_GENNS_PACK-1 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 344 secs. --> (v9.39) ZUBAIR |
08-28-2017, 20:25 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Location: R BiH Age: 49
Member: 68842 Status: Offline Thanks Meter: 9 | thank you for your answer and time but problem was in diag port enabling because like i said there is no help file i i use help file from m210 model |
The Following User Says Thank You to fill For This Useful Post: |
08-28-2017, 20:34 | #5 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | PC detect any interface from this phone? Try install LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe and connect in Charge Only, PTP, MTP mode. PC must detect LG port. -- |
08-28-2017, 22:03 | #6 (permalink) |
Member: 68842 Status: Offline Thanks Meter: 9 | no andrew it was useless trying but after *#546368#*200# and port check test enabled everything is fine of course also imei 0 fix needed |
08-29-2017, 13:41 | #7 (permalink) | |
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Quote:
and if you are not new in all latest lg phones you have to enable port check on thanks | |
04-30-2018, 21:16 | #8 (permalink) |
Junior Member Join Date: Dec 2015 Location: Trebinje Age: 34
Member: 2508042 Status: Offline Thanks Meter: 3 | M200n qcn Can you send me qcn file for m200n? I have Z3X activated, but imei repair stuck 2-3g tool and nothing happened until unplug cable. Imei is null |
05-02-2018, 08:16 | #11 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | Problem with phone connection (do you enable diag port?). Check drivers, cable, try in another PC. -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
