Old 01-22-2016, 19:36   #1 (permalink)
Crazy Poster
Member: 504430
Thanks Meter: 14
LG V10 Port Check Test?
I have a LG V10 At&t H900 phone. For me to service the phone I need to enable the diagnostic port by enabling the port check test in the service menu.
Does anyone know what keys to type in?
277634#*# does not work
3845#*900# does not work
Thanks in advance
Gene
Old 01-22-2016, 20:20   #2 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Thanks in advance
Gene
https://play.google.com/store/apps/d...oidsecretcodes
download and install this software. Check code how show sotfware.
Old 01-22-2016, 21:16   #3 (permalink)
Crazy Poster
Member: 504430
Thanks Meter: 14
Hi Andrew,
Thank you for your reply. The codes in the app don't work for this At&t LG V10 phone I have. How did you guys do it? Obviously you guys got it to work since you put IMEI service option in 8.8 update for H900 phone. Please let me know what key input to dial in phone.
Thanks in advance
Gene
Old 01-22-2016, 21:23   #4 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hi Andrew,
Thanks in advance
Gene
Root phone and contact to me in pm.
Old 01-23-2016, 05:22   #5 (permalink)
Member: 2343867
Thanks Meter: 2
Any news on this ? I have one to same thing need to enable port check test but no codes work
Old 01-23-2016, 09:35   #6 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Root phone after root enable diag.
Old 01-23-2016, 20:37   #7 (permalink)
Member: 2343867
Thanks Meter: 2
do you know of root solution for the at&t H900 I've only found for the H901
Old 02-10-2016, 02:09   #8 (permalink)
Crazy Poster
Member: 2117969
Thanks Meter: 6
still no port test method? please help i have a h900
Old 02-10-2016, 07:15   #9 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Kinguser 4.6.2.apk try root using this root apk.
Old 02-10-2016, 10:52   #10 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Or use this code: *#546368#*900#-> Port check Test -> set Enable.
Old 02-10-2016, 19:29   #11 (permalink)
Member: 1012390
Thanks Meter: 95
Or use this code: *#546368#*900#-> SCV > Port check Test -> set Enable.
The Following User Says Thank You to Hoayeu105 For This Useful Post:
Old 09-26-2016, 07:00   #12 (permalink)
Member: 558861
Thanks Meter: 26
i enable port but still no port on device manger only portable showing
Old 09-26-2016, 07:57   #13 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Connect phone in Charge or MTP mode. Install latest LG driver( LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe)
Old 10-12-2016, 09:50   #14 (permalink)
Member: 1777225
Thanks Meter: 4
cant enable in lg g4 stylus
cant enable in lg g4 stylus only disable screen in svc screen
Old 10-12-2016, 10:11   #15 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
If you can't enable you must root phone and in adb shell run this cmd:
su
echo 1 > /sys/devices/platform/lg_diag_cmd/diag_enable
The Following User Says Thank You to andrew_tm For This Useful Post:
Page generated in 0.19968 seconds with 8 queries
