08-02-2021, 00:37 | #18 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | No Luck with 43.7 still the same...stuck on Executing 1st step... Logs Quote:
08-03-2021, 18:44 | #22 (permalink) | |
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | @Z3X Team Please solve my problem Now its giving other error... Logs... Quote:
08-03-2021, 19:44 | #23 (permalink) | ||
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Special Thanks to Z3X Team...!!! Special Thanks to Z3X Team...!!! Finally Repaired Problem Solved... Logs Repair Quote:
Patch Certificate Quote:
The Following User Says Thank You to shaikh_shoeb50 For This Useful Post: |
04-14-2022, 12:25 | #24 (permalink) |
Freak Poster Join Date: Mar 2013 Location: u can't reach Age: 31
Member: 1906916 Status: Offline Sonork: unlocker_007 Thanks Meter: 12 | i have same error in samsung a515f stuck at executing 1s step can u please tell me what to do latest z3x version tried other PC but same also tried with u3 u4 both binary but same error REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Repair Selected model: SM-A515F Software version: 43.27 Waiting ADB device... OK Reading phone info... Model: SM-A515F Android version: 10 PDA version: A515FXXU4CUA1 CSC version: A515FOJM4CUA2 Phone version: A515FXXU4CUA1 Product code: SM-A515XZBAXSG CSC country code: UAE CSC sales code: XSG Carrier ID: XFA Phone SN: R58M IMEI: HW version: MP 0.3D RF cal date: 20191213 Chip name: EXYNOS9611 Modem board: SHANNON337 Security patch: 2021-01-01 Boot Warranty bit: 1 SIM State: LOADED,LOADED Checking Super user right... true Root version: 63a89d9f:MAGISKSU Checking data... OK Searching server... OK Checking server answer... OK Data preparation... OK Initialization zTool... OK Running zTool, please wait... OK Executing 1st step... |
