02-21-2023, 16:02 | #1 (permalink) |
Junior Member Join Date: Jun 2022 Location: dubai
Member: 3015319 Status: Offline Thanks Meter: 0 | N975U invalude sim how to fix To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To unlock using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock SPR via Server NEW Selected model: SM-N975U Software version: 45.0 Checking Login and Password... OK Balance: 40 crd. You have 40 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N975U Android version: 11 PDA version: N975USQU7FUJ8 CSC version: N975UOYN7FUJ8 Phone version: N975USQU7FUJ8 Product code: SM-N975UZSASPR CSC country code: USA CSC sales code: SPR Carrier ID: SPR Phone SN: RF8N508Q5GW IMEI: xxxxxxxxxxx HW version: REV1.0 RF cal date: 2020.05.08 Chip name: SM8150 Modem board: SM8150 Security patch: 2021-11-01 Boot Warranty bit: 0 SIM State: ABSENT SIM card is not detected, insert not SPR SIM card Done with Samsung Tool PRO v.45.0 [SM-N975U,Unlock SPR via Server NEW] how to fix this |
