03-25-2013, 17:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1881612 Status: Offline Thanks Meter: 3 | need help i9000 |
03-25-2013, 17:20 | #2 (permalink) |
Member: 1881612 Status: Offline Thanks Meter: 3 | Model: GT-I9000 Country code: - Cal date: 2010-06-06 Factory SW: OXAJE3 Unique number: 74460000432582 Memory phone: KB100D00WM(I9000) Software version: IMEI: Product code: Bypass MSL... OK Repairing IMEI... OK Repair done but its not chaNGED IT PLEASE NEED HELP Reseting... OK Done with Samsung Tool v.14.2 Done with Samsung Tool v.14.2 |
03-25-2013, 17:31 | #3 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Ok, first lesson, don't play with these kind of stuff when set is working fine. Now, what firmware was installed in your set ? |
03-25-2013, 17:39 | #6 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | I guess it will be possible to fix... You have to stay calm though, to avoid making more trouble on your set. First you can try to download an other version of tool, download the oldest you can find on z3x support site, then try to repeat repair, just once. |
The Following User Says Thank You to cycofcgb For This Useful Post: |
03-25-2013, 17:41 | #7 (permalink) | |
Member: 1881612 Status: Offline Thanks Meter: 3 | Quote:
ok ill try that am useing the newest also am i rite to have use cable in then when it boots up i switch for the service cable or do i just use usb | |
03-25-2013, 18:58 | #10 (permalink) | |
Member: 1881612 Status: Offline Thanks Meter: 3 | hi reply Quote:
hi dont no what i have done but its working now the imei that i was trying to get back is the one but simlar i must of wrote it in wrong but it still did not work do turnd phone off and left for 30 mins i turned it on and its working strange still dont no how i did it lol need to learn fast how do i root s2 s3 with the z3x is there a file to down load from support for the root thanks for ur help | |
03-25-2013, 20:52 | #11 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Actually in most cases, z3x will auto-root your sets. When you connect one, let adb drivers get correctly installed (each time you connect a new set), then click on save efs. Saving efs BEFORE trying to work on any s2 or S3 (or other similar types of phones) is essential in case something goes wrong. During this procedure, z3X will root your phone, then after you can unlock easily. For some firmwares, that won't be possible. You'll have to root it on your own. In this case we'll guide you in your first steps. |
03-25-2013, 20:58 | #12 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | One more thing, start to download as much firmwares as possible for usual sets : Galaxy phones, Note I and II,and so on. Download also Odin flasher and multiloader. Both are official samsung flashers. They are more reliable to flash your sets. There are different versions of each tool, but you can download today odin v1.85 and multiloader 5.67, these are the most useful versions to start. |
03-26-2013, 20:46 | #15 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Yes, Samsung phones are great about that point, just flash firmware and your phone is debranded. An other trick : avoid unlocking phones with 4.0.3 or 4.0.4, some of these firmwares may have a weak part that may brick your phones. Flash any other firmware before working. And as said before, always save efs before anything ! |
