02-11-2017, 02:15 | #1 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | NO BOX Galaxy Grand Prime Cricket G530AZ Samsung Account Reactivation Bypass Removal 1. Set your phone in download mode. Turn your phone off. Press the volume DOWN, Home Button, and Power button at the same time. Then click the volume DOWN button to enter to download mode. 2. With the Odin included in the link below folder, use the "CP " slot to flash the file that says "Flash this first.bin" (Thank you angel3181988 for the download link): https://mega.nz/#F!XYw2TbpK!KTCsEMp3yXs0xeqMPn8pQg 3. After that, boot the phone normally and go to your Samsung sign in screen. 4. Enter your own Samsung Account information (email and password) and click next. If you do not have a Samsung Account, you can set up one by clicking on https://www.samsung.com/us/support/account/ and going to "Sign UP". 5. After that, the Samsung Reactivation screen should come up. YOU MUST deactivate the FRP red check mark in the screen. Then get to the phone home screen. 6. Then, turn your phone off and go back to download mode. With Odin flash the "CP" slot again but this time with the phone's original "Modem.bin" file. (To get your original modem.bin, download your corresponding firmware and extract it to a folder with 7Zip software or any other unzipper program. In the extracted folder, you will find the "Modem.bin" file that you need) 7. After the Modem flash, the phone will then boot to the home screen. 8. Go to settings, Factory Reset, enter your Samsung password for reset confirmation, and do the factory reset. The phone should now reset CLEAN and CLEAR!!! :-) Thanks again to "angel3181988" for the download link. PLEASE DO NOT FORGET ON THE THANKS BUTTON! |
The Following 18 Users Say Thank You to GalaxyVibe For This Useful Post: |
02-18-2017, 21:44 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | I had faced re actvation lock in s6 crciket.. and removed manually with my own procedure.. But you are telling about flashing modem first..Re activation lock has nothing to do with modem.. I'm not doubting on your procedure but technically it is not acceptable. |
02-18-2017, 21:50 | #6 (permalink) | |
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
http://forum.gsmhosting.com/vbb/f453.../#post12280856 CLICK ON THE THANKS BUTTON IF THE POST WAS HELPFULL | |
02-26-2017, 20:28 | #7 (permalink) |
Freak Poster Join Date: May 2012 Location: Nigeria
Member: 1765167 Status: Offline Thanks Meter: 71 | Trying to bypass Samsung account from G530AZ. See my Odin Log: <ID:0/015> Added!! <ID:0/015> Odin engine v(ID:3.1100).. <ID:0/015> File analysis.. <ID:0/015> SetupConnection.. <ID:0/015> Initialzation.. <ID:0/015> Get PIT for mapping.. <ID:0/015> Firmware update start.. <ID:0/015> SingleDownload. <ID:0/015> flash this first .bin <ID:0/015> NAND Write Start!! <ID:0/015> Transmission Complete.. <ID:0/015> Now Writing.. Please wait about 2 minutes <ID:0/015> Receive Response from boot-loader <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/015> Removed!! From the log the process failed. I went on to input my Samsung account details anyways but I get the "Processing failed" response. What could be wrong? |
02-26-2017, 21:03 | #8 (permalink) | |
