11-07-2018, 21:00 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | SM-N950u TMB unlock - server issue [Solved] UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-N950U Software version: 34.3 Checking Login and Password... OK Ballance: 32 crd. You have 32 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 8.0.0 PDA version: N950USQU5CRIA CSC version: N950UOYN5CRIA Phone version: N950USQU5ARF1 Product code: SM-N950UZVATMB CSC country code: USA CSC sales code: TMB Phone SN: R28J947QAHN IMEI: 358503083438938 HW version: REV1.0 RF cal date: 2017.09.30 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-09-01 Boot Warranty bit: 0 SIM State: ABSENT Searching Samsung diag port... not found Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM4 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.34.3 |
11-07-2018, 21:35 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,251 | Ask your grandma to search in forum http://forum.gsmhosting.com/vbb/f453...wered-2489321/ |
11-07-2018, 22:29 | #3 (permalink) | |
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
Read what i wrote on the top of my post before writing foolish answers that your idiot grandmer taught you | |
The Following 2 Users Say Thank You to kachman For This Useful Post: |
11-08-2018, 07:30 | #5 (permalink) | |
Drivers are all there, and I dont think this phone needs diag port because i've unlocked tmb phones many times and never needed to enable diag port Looks like a server issue to me. Or maybe phone needs flashing | |
11-08-2018, 19:52 | #8 (permalink) | |
Maybe its just the common "search forum" disease that everyone seems to suffer from once they think they are forum gurus after making 10 posts | |
11-09-2018, 22:32 | #12 (permalink) |
Member: 272581 Status: Offline Thanks Meter: 118 | dont worry about it, I just found out the problem is that the phone is Sprint but it was apparently converted to TMB. so im undoing whatever was done on it and then unlock it as sprint |
