Old 10-14-2018, 22:38   #1 (permalink)
Member: 181674
SM-N950u t-mobile can't unlock [Answered]
hello dear z3 team i have note 8 t-mobile n950u
cant unlock any help
this is log
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will appear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Unlocking using Server:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Unlock
Selected model: SM-N950U
Selected port: COM21 SAMSUNG Mobile USB Serial Port
Software version: 33.8
Checking Login and Password... OK
Ballance: 33 crd.
You have 33 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-N950U
Android version: 8.0.0
PDA version: N950USQS5CRG9
CSC version: N950UOYN5CRG9
Phone version: N950USQS5CRG9
Product code: SM2N950UZKATMB
CSC country code: USA
CSC sales code: TMB
Phone SN: R28K91Q9JXA
IMEI: 358505086766611
HW version: REV1.0
RF cal date: 2018.09.19
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-08-01
Boot Warranty bit: 0
Searching Samsung diag port... detected COM21
Reading phone info... OK
Reading data from phone... error (0), skip
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Rebooting to upload... OK
Searching Ramdump interface... COM6 detected
Calculating... error (0)
Done with Samsung Tool PRO v.33.8
best regards
Old 10-14-2018, 22:47   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Search and you will find that you should flash eng modem from combination and repet unlock
Old 10-14-2018, 22:55   #3 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
http://www.mediafire.com/file/5uc05w..._BIT5.tar/file
The Following User Says Thank You to souma_k For This Useful Post:
Page generated in 0.14626 seconds with 8 queries
