10-11-2018, 21:24 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: FLA, US Age: 47
Member: 31969 Status: Offline Thanks Meter: 13 | SM-N920W8 FRP error? [Answered] "Custom Binary(USERDATA) Blocked by FRP lock" and is frozen... Also another screen popped up saying: "An error has occurred while updating the device s/w use the emergency recovery function..." Operation: Reset FRP/React/EE Selected model: SM-N920W8 Selected port: COM131 Z3X BOX Serial Port Software version: 33.8 Searching Samsung USB Flash interface... COM6 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.8 |
The Following User Says Thank You to toshik For This Useful Post: |
10-11-2018, 22:13 | #3 (permalink) |
Member: 31969 Status: Offline Thanks Meter: 13 | Turns on with this message "An error has occurred while updating the device s/w use the emergency recovery function..." Battery reconnect does not help |
10-13-2018, 02:02 | #8 (permalink) |
Member: 31969 Status: Offline Thanks Meter: 13 | FRP is off, reflashed stock ROM of the same version from downloads sections, still the same exact message in recovery upon factory reset "E: failed to mount /preload (No such file or directory) No big deal as long as it does not affect anything else. Can do OTA if it would help. |
