07-28-2017, 07:46 | #1 (permalink) |
Junior Member Join Date: Nov 2003 Age: 53
Member: 45057 Status: Offline Thanks Meter: 3 | please help for unlock samsung account a300fu im new for z3x i want to unlock samsung account a300-fu i have latest samsung pro 29.00 and uart cable i try to unlock but dont let me to flash combination file because z3x can not see a300-fu i try both normal usb and uart but nothing maybe because adb is off i donwload and adbunlock 20gb file but i dont know how use in download mode i can reactivation lock on secure download enable qualcomm secureboot enable (csb) |
07-28-2017, 07:53 | #2 (permalink) | |
Insane Poster Join Date: Jun 2017
Member: 2727335 Status: Offline Sonork: marten Thanks Meter: 13 | Quote:
The Following User Says Thank You to marten21 For This Useful Post: |
07-28-2017, 08:27 | #5 (permalink) |
Member: 45057 Status: Offline Thanks Meter: 3 | """"Install driver correctly,tap *#0*# connect uart cable and hit unlock """ thank you where i must type *#0*# ???? phone is after recovery.....start like NEW phone....stop when say tap samsung account i cant go to dialer Last edited by freecom; 07-28-2017 at 08:36. |
07-28-2017, 09:45 | #6 (permalink) |
Member: 45057 Status: Offline Thanks Meter: 3 | i have news drivers ok......pc can see phone ....in download mode and normal on mode in download mode z3x not see with normal and uart cable only in normal mode with on phone and uart cable z3x see phone and say reading imei......ok imei.......0 unlock ......error (1) |
07-28-2017, 10:21 | #8 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | download combination from suppot then flash combination wait for phone to fully boot then go to any phone in samsung z3x pro that enables rest frp by adb like g935f reset frp via adb select the port and reset after wads rest phone from seetings menu then check in dwonload mode if reactivation lokkff then flash full firmware |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
07-28-2017, 12:54 | #9 (permalink) |
Member: 45057 Status: Offline Thanks Meter: 3 | its crazy i make combination flash .....then unlock with z3x one clik Serial com (modem and adb on)......unlock ok.....then factory reset.....then flash full rom.....then samsung account still here i make combination flash.....then unlock as g935 adb port.......unlock ok......factory reset......then full flash rom.....then samsung account still here crazy |
07-28-2017, 12:58 | #10 (permalink) | |
