04-05-2016, 12:55 | #15961 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected port: COM90 Qualcomm HS-USB Diagnostics 9002 Selected port speed: 115200 Searching Samsung modem... detected COM89 Reading phone info... Software version: T199UVNBA IMEI: 35842005441700 /9 Product code: xxxxxxxxxxxxxx Bypass MSL... OK Unlocking... OK Unlock done Codes set to 00000000 Done with Samsung Tool v.19.1 |
04-05-2016, 17:23 | #15962 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Reset FRP/React/EE Selected model: SM-G928A Software version: 25.0 Searching Samsung USB Flash Interface... detected COM11 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.0 |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
04-05-2016, 18:37 | #15963 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Flash Selected model: SM-G935F Software version: 25.0 File analysis... OK Total file size: 0x0C1C3100 (193 Mb) Searching USB Flash Interface... detected COM11 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:04:14) Done with Samsung Tool PRO v.25.0 |
04-06-2016, 05:24 | #15964 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | note 5 unlock done by 23.9 UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920T Software version: 23.9 Waiting ADB device... OK Reading phone info... Model: SM-N920T Android version: 5.1.1 Product code: SM-N920TZWATMB Phone version: N920TUVU2COI5 PDA version: N920TUVU2COI5 CSC version: N920TTMB2COI5 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8GA1QY5WP Modem board: SHANNON333 RF cal date: 20151019 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.9 |
04-06-2016, 06:46 | #15965 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Selected model: S3310 Selected com port: COM33 Selected speed port: 921600 Please, connect phone and press shortly power button Detect broadcom2... OK Switching to boot mode... OK Erase NAND - start Erase NAND - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send IMG NAND ... Send IMG - ok Send TFS ... Send TFS - ok Download - ok Elapsed time: 882 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
04-06-2016, 08:02 | #15967 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Samsung C3590 Unlock OK Operation: Unlock Selected model: GT-C3590 Selected port: Auto, 921600 Software version: 25.0 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... OK Patching firmware block... OK Erase Flash... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM70 Reading phone info... Model: GT-C3590 Country code: PHE Factory SW: C3590XXMH2_OXCMH3 Unique number: 24841150095319 Memory phone: K521H12ACH(C3592)S Software version: C3590ADMG1/C3590O2UMG2 IMEI: 355058xxxxxxxx Reading Phone S/N... OK Phone S/N: RV1F70R3VK Bypass MSL... OK Unlocking... OK Done with Samsung Tool PRO v.25.0 |
04-06-2016, 15:46 | #15968 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | J200G Read codes ok !!! Quote:
04-06-2016, 17:52 | #15969 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G920T Software version: 25.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G920T Android version: 5.1.1 Product code: SM-G920TZWATMB Phone version: G920TUVS3DOJC PDA version: G920TUVS3DOJC CSC version: G920TTMB3DOJC CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58G40NVGPV Modem board: SHANNON333 RF cal date: 20150413 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.0 |
04-06-2016, 20:04 | #15970 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Reset FRP/React/EE Selected model: SM-G360T1 Software version: 25.0 Searching Samsung USB Flash Interface... detected COM8 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.0 |
04-07-2016, 01:58 | #15971 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-N910A Selected port: COM116 SAMSUNG Mobile USB Serial Port Software version: 25.0 Reading phone info... Reading IMEI... OK IMEI: 3562XXXXXXXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.0 Operation: Unlock Selected model: SM-N910A Selected port: COM119 SAMSUNG Mobile USB Serial Port Software version: 25.0 Reading phone info... Reading IMEI... OK IMEI: 35448XXXXXXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.0 Operation: Unlock Selected model: SM-N910A Selected port: COM122 SAMSUNG Mobile USB Serial Port Software version: 25.0 Reading phone info... Reading IMEI... OK IMEI: 3544XXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.0 |
04-07-2016, 09:02 | #15972 (permalink) |
No Life Poster Join Date: Feb 2010 Location: pakistan(Timergara) Age: 37
Member: 1224733 Status: Offline Thanks Meter: 158 | Galaxy ALFA G850F unlocked Waiting ADB device... OK Reading phone info... Model: SM-G850F Android version: 4.4.4 Product code: SM-G850FHSEO2U Phone version: G850FXXU1BNK2 PDA version: G850FXXU2BNK3 CSC version: G850FO2U2BNK1 CSC country code: UK & IRE CSC sales code: O2U HW version: MP 1.100 Phone S/N: R58FA1FAC9A Modem board: XMM7260 RF cal date: 2014.10.30 IMEI: 356010068377364 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.0 |
04-07-2016, 12:29 | #15973 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Samsng E1270 flashing done Code: Selected model: E1270 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM92 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1270_7-4-2016_14-23-2.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:01:05) Done with Samsung Tool v.18.9 |
The Following User Says Thank You to sebY7676 For This Useful Post: |
04-07-2016, 21:37 | #15974 (permalink) |
Junior Member Join Date: Jul 2012 Location: Anderson
Member: 1788705 Status: Offline Thanks Meter: 9 | Sprint Galaxy S4 domestic unlock!! Operation: Unlock SPRNT Selected model: SPH-L720T Selected port: Software version: 25.0 Waiting ADB device... OK Reading phone info... Model: SPH-L720T Android version: 5.0.1 Product code: Not Active Phone version: L720TVPUAMK5 PDA version: L720TVPUCOK3 CSC version: L720TSPTCOK3 CSC country code: USA CSC sales code: SPR HW version: L720T.03 Phone S/N: 00000000000 Modem board: MDM9615M RF cal date: 2014.04.21 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.0 |
The Following User Says Thank You to qper For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
