10-12-2016, 23:59 | #11 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | FRP AND UNLOCK N920P BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read SEC' button to read security area backup or 'Write SEC' to restore it or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC' (ignore it, if not available). Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Reset FRP/React/EE Selected model: SM-N920P Software version: 26.9 Searching Samsung USB Flash interface... COM4 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 .................................................. ................ UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock SPRNT Selected model: SM-N920P Software version: 26.9 Waiting ADB device... OK Reading phone info... Model: SM-N920P Android version: 5.1.1 Product code: Not Active Phone version: N920PVPU2AOI6 PDA version: N920PVPU2AOI6 CSC version: N920PSPT2AOI6 CSC country code: USA CSC sales code: SPR HW version: N920P.03 Phone SN: 00000000000 Modem board: MDM9635M RF cal date: 2015.07.24 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
