08-14-2017, 13:27 | #18916 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose phone USB. 3. Type *#1575#, press 'MENU' button, press 'BACK', choose 'DIAG' - 'USB'. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Repair Selected model: GT-I9001 Selected port: COM65 SAMSUNG Android USB Diagnostic Serial Port (WDM) Software version: 29.1 Checking phone at COM65 Reading phone info... Phone SN: RFXBA09942 PDA/CSC version: I9001XXKI2/I9001DBTKG1 Phone version: I9001XXKI2 Phone HW: MP 0.500 Cal date: 2011.10.18 Reading IMEI... OK IMEI: 357853047524963 Reseting MSL... OK Bypass MSL... OK Repairing IMEI... OK Reseting... OK Repair done Done with Samsung Tool PRO v.29.1 |
08-14-2017, 14:56 | #18917 (permalink) |
Junior Member Join Date: Sep 2015 Location: I'm on the street where u live
Member: 2456598 Status: Offline Thanks Meter: 3 | UNLOCK INSTRUCTIONS: USB mode : 1. Power on the phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect the phone to PC, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Or you can 'Read User Lock' or 'Reset User Lock'. Operation: Reset User Lock Selected model: GT-S8500 Software version: 29.1 Searching Samsung modem... detected COM429 Reading phone info... OK Model: GT-S8500 Phone version: S8500XXJH3 IMEI: 351781048108476 Reseting phone lock... OK Phone lock: 00000000 Reseting SIM lock... OK SIM lock: 00000000 Done with Samsung Tool PRO v.29.1 |
08-14-2017, 15:26 | #18918 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Samsung SM-G925F Reset Pattern Lock Successfully w/o Data Loss Code: Operation: Reset Pattern Lock Selected model: SM-G925F Selected port: COM358 SAMSUNG Mobile USB Serial Port Software version: 29.1 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM12 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G925FXXU5DQA7 Platform: exynos7420 Boot serial: 03157df3d1897808 Product board: zerolte Erasing locks... OK Rebooting phone... OK Reset locks done Done with Samsung Tool PRO v.29.1 |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
08-15-2017, 12:38 | #18919 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J700T1 Software version: 29.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J700T1 Android version: 6.0.1 Product code: SM2J700TZWATMK Phone version: J700T1UVS3AQF1 PDA version: J700T1UVS3AQF1 CSC version: J700T1TMK3AQF1 CSC country code: USA CSC sales code: TMK HW version: REV0.5 Phone SN: R58H82DDF8P Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160814 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: F4 EE 31 A3 33 D8 15 26 F8 9C 81 24 AC E8 C0 0E Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-15-2017, 12:38 | #18920 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Kumasi-Ghana
Member: 1608526 Status: Offline Sonork: 100.1611913 Thanks Meter: 60 | A310f 7.0 unlock done Operation: Unlock Selected model: SM-A310F Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-A310F Android version: 7.0 Product code: SM2A310FZKATMH Phone version: A310FXXU3CQE7 PDA version: A310FXXU3CQF6 CSC version: A310FTMH3CQF1 CSC country code: HUNGARY CSC sales code: TMH HW version: MP 0.200 Phone SN: R58H81801PP Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160809 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: E9 98 39 F9 51 B4 85 16 D2 5C 31 14 3A 18 31 7E Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 POWER TEAM....................... |
08-15-2017, 16:53 | #18922 (permalink) |
Freak Poster Join Date: Apr 2015 Location: pakistan
Member: 2383595 Status: Offline Sonork: 100.1681107 Thanks Meter: 10 | Hi bro I have to s7 g930fd so i do patch in verion 7.0 that is not suported so i request you sir add this one model suport in patch Sent from my SM-G930F using Tapatalk |
08-16-2017, 04:17 | #18924 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | G950W Read codes. Code: Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZVACHR Phone version: G950WVLU1AQDE PDA version: G950WVLU1AQDE CSC version: G950WOYA1AQDE CSC country code: Canada CSC sales code: CHR HW version: REV1.0 Phone SN: xxxxxxxxxxxA Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.06.08 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 36xxx503 NET lock: 61xxx429 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# |
08-16-2017, 09:05 | #18925 (permalink) |
No Life Poster Join Date: Oct 2008 Location: chennai
Member: 880497 Status: Offline Thanks Meter: 197 | A510F 7.0 Unlock Done Samsung A510F 7.0 Unlock Done Without Downgrade Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-A510F Android version: 7.0 Product code: SM-A510FZDFINS Phone version: A510FDXXU4CQF6 PDA version: A510FXXU4CQG4 CSC version: A510FDODD4CQG1 CSC country code: India CSC sales code: INS HW version: MP 0.000 Phone SN: R58H20JW67W Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-07-01 RF cal date: 20160206 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 3C A8 A7 42 AF CD 3C 04 B8 C5 3A 82 A9 FF A9 2F Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 69303826 NET lock: 60261618 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 |
08-16-2017, 09:23 | #18926 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung T679m Unlock done by read code Operation: Read Codes Selected model: SGH-T679M Selected port: COM10 Z3X BOX Serial Port Software version: 29.1 Checking phone at COM10 Reading phone info... Phone SN: R21C50CMVQ PDA/CSC version: T679MUGKK1/T679MBMCKK1 Phone version: T679MUGKK1 Phone HW: REV0.1 Cal date: 2012.05.05 Reading IMEI... OK IMEI: 35152105xxxxxxx Reseting MSL... OK Bypass MSL... OK Reading codes... OK Freeze code: 17472685 NET lock: 59316282 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.1 Thanks z3x Team |
08-16-2017, 10:36 | #18927 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | GT-S7582 Emergency Calls Only Solved via One Click Code: Operation: Repair Selected model: GT-S7582 Software version: 29.1 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-S7582 Android version: 4.2.2 Product code: Phone version: S7582DDUAMK1 PDA version: S7582DDUANA1 CSC version: S7582ODDANA1 CSC country code: India CSC sales code: INU HW version: MP 0.101 Phone SN: R21F62M29MB Modem board: RF cal date: 20140613 IMEI: 3542180---------- Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.1 |
08-16-2017, 18:54 | #18928 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | G920A Unlock Done.. Easyway Operation: Unlock Selected model: SM-G920A Selected port: COM55 SAMSUNG Mobile USB Serial Port Software version: 29.1 Searching Samsung modem... detected COM54 Reading phone info... OK Model: SM-G920A AP version: G920AUCS6DQC1 CSC version: G920AATT6DQC1 CP version: G920AUCU6AQC1 Product code: SM2G920AZKAATT Phone SN: RF8H10ZSAXX Unique number: 1215FC1441E33304 Reading IMEI... OK IMEI: 35180807015XXX (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done |
08-17-2017, 16:30 | #18929 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Operation: Unlock Selected model: SGH-T139 Selected port: COM192 Z3X BOX Serial Port, 460800 Software version: 29.0 Connect phone and press power button... Phone detected Switching phone to TAT mode... OK Reading phone info... OK Phone version: T139UVJC1 IMEI: 01219500660049 Phone SN: RPUZ764218 Phone BT: D4:E8:B2:EB:4B:5A Reading security... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-17-2017, 16:39 | #18930 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | A310F FRP DONE A310FXXU3BQC8_A310FOJV3BQC8 Waiting ADB device... OK Reading phone info... Model: SM-A310F Android version: 6.0.1 Product code: SM-A310FZKAXEU Phone version: A310FXXU3BQC2 PDA version: A310FXXU3BQC2 CSC version: A310FXEU3BQC2 CSC country code: UK & IRE CSC sales code: XEU HW version: MP 0.200 Phone SN: R28H436F6AW Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-02-01 RF cal date: 20160427 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 BLACKSCREEN REV ERROR BINARY SOLUTION 1 FIRST FLASH COMBINATION FULL COMBINATION_FAC_FA51_A310FXXU3AQC1 AND ENABLE USB DEBUGGING DONT DO ANY FACTORY RESET JUST PUT IT IN DOWNLAOD MODE AGAIN 2 FLASH THIS FIRMWARE A310FXXU3BQC2_A310FXEU3BQC2 GET IT FROM SAMFIRMWARE WHEN THE PHONE IS ON USB BUGGING IS ON 3: USE Z3X FOR FRP ADB 4: WHEN YOU ARE INSIDE THEN GO TO SETTING AND DO FACTORY RESET PROFIT IF THIS HELP YOU CLICK ON THANKS |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
