08-12-2017, 11:33 | #18901 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Selected model: SGH-M150 Selected port: COM192 Z3X BOX Serial Port, 460800 Software version: 29.0 Connect phone and press power button... Phone detected Switching phone to TAT mode... OK Reading phone info... OK Phone version: M150AXIA3 IMEI: 35464002213065 Phone SN: R7XS109647 Phone BT: 00:237:7B:FF:83 Reading security... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-12-2017, 11:33 | #18902 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Read EFS Selected model: SM-E500H Selected port: COM3 USB Serial Port Software version: 29.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-E500H Android version: 5.1.1 Product code: SM-E500HZKATUR Phone version: E500HXXU1BOI5 PDA version: E500HXXU1BPK1 CSC version: E500HOJV1BPJ3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: RV1G51M6Z7T Modem board: MSM8216 Security patch: 2016-11-01 RF cal date: 2015.05.22 IMEI: Checking Super user right... true Reading EFS from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\EFS\EFS_SM-E500H_E500HXXU1BPK1__RV1G51M6Z7T_12-8-2017_1-31-2.tar Done with Samsung Tool PRO v.29.0 |
08-12-2017, 13:11 | #18903 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool Successfully REMOVE USER CODE(SAMSUNG S3353)USB Selected model: S3353 Selected com port: COM39 Selected speed port: 921600 Phone must be ON Use UART cable E210 or J750 Phone IMEI: 35597704388564/00 Phone SN: RDKB429504 Phone SN: S3353DDKC1 Phone user code: 8888 Read user code - ok Elapsed time: 3 second, sw ver: 3.5.0040 THANKS Z3X-BOX TEAM |
08-12-2017, 13:39 | #18904 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Operation: Flash Selected model: GT-S3572 Software version: 29.0 Load model info... OK Loading BIN PTT file... OK Loading CSC PTT file... OK Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... OK Link type set to USBF Reading OTP... OK OTP register: 473E8100 PKI security mode detected Protected device detected Reading product ID... OK Product ID: 0x 0 6502018E8E4 0 Reading SCROM version SCROM version - 0x 31 Chipset version - 0x 48 Downloading Loader of main loader in Internal RAM... OK Start PreLoader... OK Wait for device... OK Checking device descriptions... OK Loader verison... 7.5.16 Uploading INT loader to S/D-DRAM Interface... DDRAM detected Flash memory parameters Capacity params: 0 Datawidth - 0 Block number - 0 Block size - 0 Buffer prog. Timing params: 0 ms erase block time - 0 us write buffer time Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 5 Buffer type - 1024 Buffer size - 1024 Tansfert size - 0 Tansfert RAW size Bad Block params: 0 Bad block reservoir size Wait for device... OK Checking device descriptions... OK Loader verison... 7.5.16 NAND flash memory SSG_K521F12ACH-B050 detected Flash memory parameters Capacity params: 1 Datawidth - 1024 Block number - 128 Block size - 0 Buffer prog. Timing params: 6 ms erase block time - 600 us write buffer time Send Loader and NAND Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 3 Buffer type - 66958336 Buffer size - 32768 Tansfert size - 32768 Tansfert RAW size Bad Block params: 22 Bad block reservoir size SW Boot version: 5 Get First Block... OK Prepare FirstBlock... OK FirstBlock Must Be updated Erase First Block... OK Set Partition Params... OK Downloading FirstBlock in Flash... OK Init Bad Block Managment... OK Send Verify Cmd... OK Erasing Partition_1... OK Erasing Partition_2... OK Erasing Partition_3... OK Erasing Partition_4... OK Erasing Partition_5... OK Erasing Partition_6... OK Erasing Partition_7... OK Erasing Partition_8... OK Erasing Partition_9... OK Erasing Partition_10... OK Erasing Partition_12... OK Programming Partition_1 Prepare CRC32... OK Set Partition Params... OK Download Partition_1 IMAGE... OK Checking CRC32... OK Programming Partition_2 Prepare CRC32... OK Set Partition Params... OK Download Partition_2 LCDACT... OK Checking CRC32... OK Programming Partition_3 Prepare CRC32... OK Set Partition Params... OK Download Partition_3 DATA_RW... OK Checking CRC32... OK Programming Partition_4 Prepare CRC32... OK Set Partition Params... OK Download Partition_4 DSP... OK Checking CRC32... OK Programming Partition_5 Prepare CRC32... OK Set Partition Params... OK Download Partition_5 PAGE... OK Checking CRC32... OK Programming Partition_6 Prepare CRC32... OK Set Partition Params... OK Download Partition_6 MAIN... OK Checking CRC32... OK Programming Partition_7 Prepare CRC32... OK Set Partition Params... OK Download Partition_7 a... OK Checking CRC32... OK Programming Partition_8 Prepare CRC32... OK Set Partition Params... OK Download Partition_8 b... OK Checking CRC32... OK Programming Partition_9 Prepare CRC32... OK Set Partition Params... OK Download Partition_9 c... OK Checking CRC32... OK Programming Partition_10 Prepare CRC32... OK Set Partition Params... OK Download Partition_10 d... OK Checking CRC32... OK Programming Partition_12 Prepare CRC32... OK Set Partition Params... OK Download Partition_12 OTPW... OK Checking CRC32... OK Updating RCB... OK Flashing done (time - 00:04:27) Done with Samsung Tool PRO v.29.0 |
08-12-2017, 14:26 | #18905 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 29.0 Successfully REMOVE FRP (SAMSUNG SM-J200F)USB Operation: Reset FRP/React/EE Selected model: SM-J200F Software version: 29.0 Searching Samsung USB Flash interface... COM40 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 THANKS Z3X-BOX TEAM |
08-12-2017, 14:47 | #18906 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G532F Frp Reset Code: Operation: Reset FRP Selected model: SM-G532F Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDKSA Phone version: G532FXXU1APJ7 PDA version: G532FXWU1APJ3 CSC version: G532FOJV1APJ4 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: R58J13S48YZ Chip name: MT6737T Modem board: MT6737T Security patch: 2016-10-01 RF cal date: 20170117 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 |
08-12-2017, 14:48 | #18907 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung J500H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 29.0 Searching Samsung USB Flash interface... COM31 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.0 |
08-12-2017, 15:20 | #18908 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J700H/DS Software version: 28.2 Searching Samsung modem... detected COM201 Reading phone info... Ok Model: AP version: CSC version: CP version: Product code: Phone SN: Unique number: Reading IMEI... Ok IMEI: 358571038623441 (SIGN: NG_SIGN) IMEI 2: 358571038623458 (SIGN: NG_SIGN) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
08-12-2017, 15:23 | #18909 (permalink) |
08-12-2017, 15:23 | #18910 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700H/DS Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-J700H Android version: 6.0.1 Product code: SM-J700HZDDMID Phone version: J700HXXU3AQD1 PDA version: J700HXXS3BQE2 CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R21H60JTWNR Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-05-01 RF cal date: 20160617 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.28.2 |
08-12-2017, 16:39 | #18911 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-J710F Software version: 29.0 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDDSER Phone version: J710FXXU2AQA4 PDA version: J710FXXU2AQA8 CSC version: J710FOXY2AQA2 CSC country code: Russia CSC sales code: SER HW version: MP 0.400 Phone SN: RF8J21SEEXD Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-01-01 RF cal date: 20170216 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 36 04 00 00 00 00 00 00 00 00 00 00 26 CF 96 0E Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.0 |
08-12-2017, 16:40 | #18912 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-J710F Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDDSER Phone version: J710FXXU2AQA4 PDA version: J710FXXU2AQA8 CSC version: J710FOXY2AQA2 CSC country code: Russia CSC sales code: SER HW version: MP 0.400 Phone SN: RF8J21SEEXD Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-01-01 RF cal date: 20170216 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.0 |
08-13-2017, 07:14 | #18913 (permalink) |
Junior Member Join Date: Jun 2015 Location: kabul,Afghanistan
Member: 2413245 Status: Offline Sonork: 100.1662329 Thanks Meter: 1 | Searching Samsung modem... detected COM5 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQG5 CSC version: G955FOXM1AQG5 CP version: G955FXXU1AQG5 Product code: ATO Phone SN: R5xxxxxxxGW Unique number: CE051715AAEBBB2202 Reading IMEI... OK IMEI: 359xxxxxxxxxx23 Reading SN... OK Phone SN: R5xxxxxFG Enter MSL: 0519330xxxxxxxxxxxxxxxxxxxx212C00 Bypass MSL... OK Unlocking... OK Codes set to 00000000 Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-13-2017, 13:46 | #18914 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | g925t unlock done Operation: Unlock Selected model: SM-G925T Selected port: COM15 USB Serial Port Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 7.0 Product code: SM-G925TZKATMB Phone version: G925TUVU5FQG3 PDA version: G925TUVU5FQG3 CSC version: G925TTMB5FQG3 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone SN: R58G60FNWJL Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20150606 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 FF CE 0F 37 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
08-13-2017, 19:01 | #18915 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Assam
Member: 1189538 Status: Offline Thanks Meter: 22 | SAMSUNG j200f UNLOCKING DONE WITH ROOTING FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Unlock Selected model: SM-J200F Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SM-J200F Android version: 5.1.1 Product code: SM-J200FZDDKSA Phone version: J200FXXU3AQC1 PDA version: J200FXXU3AQC2 CSC version: J200FOJV3AQC1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: RV8J5283SCM Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 RF cal date: 20170601 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 82 B3 75 5F 14 DD 27 78 B9 9F 0E A2 00 54 B2 55 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.1 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
