Old 08-14-2017, 13:27   #18916 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
BACKUP INSTRUCTIONS:
UART cable:
1. Phone must be powered on.
2. Connect the phone to UART cable.
3. Choose correct COM port in port settings.
4. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
USB cable:
2. Type *#7284# and choose phone USB.
3. Type *#1575#, press 'MENU' button, press 'BACK', choose 'DIAG' - 'USB'.
4. Reboot phone.
5. Connect USB cable, install drivers.
6. Select diagnostic port in port settings.
7. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Repair
Selected model: GT-I9001
Selected port: COM65 SAMSUNG Android USB Diagnostic Serial Port (WDM)
Software version: 29.1
Checking phone at COM65
Reading phone info...
Phone SN: RFXBA09942
PDA/CSC version: I9001XXKI2/I9001DBTKG1
Phone version: I9001XXKI2
Phone HW: MP 0.500
Cal date: 2011.10.18
Reading IMEI... OK
IMEI: 357853047524963
Reseting MSL... OK
Bypass MSL... OK
Repairing IMEI... OK
Reseting... OK
Repair done
Done with Samsung Tool PRO v.29.1
Old 08-14-2017, 14:56   #18917 (permalink)
Member: 2456598
Thanks Meter: 3
UNLOCK INSTRUCTIONS:
USB mode :
1. Power on the phone.
2. Type *#197328640# -> common -> usb config -> Samsung mode
3. Connect the phone to PC, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Or you can 'Read User Lock' or 'Reset User Lock'.
Operation: Reset User Lock
Selected model: GT-S8500
Searching Samsung modem... detected COM429
Reading phone info... OK
Model: GT-S8500
Phone version: S8500XXJH3
IMEI: 351781048108476
Reseting phone lock... OK
Phone lock: 00000000
Reseting SIM lock... OK
SIM lock: 00000000
Old 08-14-2017, 15:26   #18918 (permalink)
EjazATF's Avatar
Member: 2192499
Sonork: Stopped using..
Thanks Meter: 1,763
Samsung
SM-G925F Reset Pattern Lock Successfully w/o Data Loss
Operation: Reset Pattern Lock
Selected model: SM-G925F
Selected port: COM358 SAMSUNG Mobile USB Serial Port
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM12 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... OK
Recovery build version: 6.0.1
Boot version: G925FXXU5DQA7
Platform: exynos7420
Boot serial: 03157df3d1897808
Product board: zerolte
Erasing locks... OK
Rebooting phone... OK
Reset locks done
The Following 2 Users Say Thank You to EjazATF For This Useful Post:
Old 08-15-2017, 12:38   #18919 (permalink)
dky_tel's Avatar
Member: 120328
Thanks Meter: 243
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
To read security codes:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Read codes' button to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J700T1
Software version: 29.0
Please, allow USB debugging on phone... OK
Model: SM-J700T1
Android version: 6.0.1
Product code: SM2J700TZWATMK
Phone version: J700T1UVS3AQF1
PDA version: J700T1UVS3AQF1
CSC version: J700T1TMK3AQF1
CSC country code: USA
CSC sales code: TMK
HW version: REV0.5
Phone SN: R58H82DDF8P
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2017-06-01
RF cal date: 20160814
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID: F4 EE 31 A3 33 D8 15 26 F8 9C 81 24 AC E8 C0 0E
Calculating... OK
Unlocking... OK
Writing NV data... OK
Unlock done
Done with Samsung Tool PRO v.29.0
Old 08-15-2017, 12:38   #18920 (permalink)
Member: 1608526
Sonork: 100.1611913
Thanks Meter: 60
Thumbs up A310f 7.0 unlock done
Operation: Unlock
Selected model: SM-A310F
Software version: 28.2
Waiting ADB device... Ok
Model: SM-A310F
Android version: 7.0
Product code: SM2A310FZKATMH
Phone version: A310FXXU3CQE7
PDA version: A310FXXU3CQF6
CSC version: A310FTMH3CQF1
CSC country code: HUNGARY
CSC sales code: TMH
HW version: MP 0.200
Phone SN: R58H81801PP
RF cal date: 20160809
IMEI:
Reading NV data... Ok
Checking NV data... Ok
Reading data... Ok
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Initialization zTool... Ok
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data... Ok
HWID: E9 98 39 F9 51 B4 85 16 D2 5C 31 14 3A 18 31 7E
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Rebooting phone... Ok
Unlock done
Done with Samsung Tool PRO v.28.2
POWER TEAM.......................
Old 08-15-2017, 16:20   #18921 (permalink)
nelson_sanchez1's Avatar
Member: 1621431
Sonork: 100.1626009
Thanks Meter: 16
a520f unlock by msl code
[IMG][/IMG]
Old 08-15-2017, 16:53   #18922 (permalink)
Member: 2383595
Sonork: 100.1681107
Thanks Meter: 10
Hi bro
I have to s7 g930fd so i do patch in verion 7.0 that is not suported so i request you sir add this one model suport in patch
Sent from my SM-G930F using Tapatalk
Old 08-15-2017, 16:53   #18923 (permalink)
Member: 2383595
Sonork: 100.1681107
Thanks Meter: 10
Plz helpe me
Old 08-16-2017, 04:17   #18924 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 288
G950W Read codes.
Checking Login and Password... OK
Ballance: 50 crd.
Model: SM-G950W
Product code: SM-G950WZVACHR
Phone version: G950WVLU1AQDE
PDA version: G950WVLU1AQDE
CSC version: G950WOYA1AQDE
CSC country code: Canada
CSC sales code: CHR
HW version: REV1.0
Phone SN: xxxxxxxxxxxA
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-04-01
RF cal date: 2017.06.08
IMEI:
Start... OK
Searching Ramdump interface... COM6 detected
Calculating... OK
Waiting for server answer... OK
Freeze code: 36xxx503
NET lock: 61xxx429
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Old 08-16-2017, 09:05   #18925 (permalink)
kathir.'s Avatar
Member: 880497
Thanks Meter: 197
A510F 7.0 Unlock Done
Samsung A510F 7.0 Unlock Done Without Downgrade
Model: SM-A510F
Product code: SM-A510FZDFINS
Phone version: A510FDXXU4CQF6
PDA version: A510FXXU4CQG4
CSC version: A510FDODD4CQG1
CSC country code: India
CSC sales code: INS
HW version: MP 0.000
Phone SN: R58H20JW67W
Security patch: 2017-07-01
RF cal date: 20160206
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: 3C A8 A7 42 AF CD 3C 04 B8 C5 3A 82 A9 FF A9 2F
Calculating... OK
Checking hash file... OK
Please wait, calculating codes... OK (time - 00:00:04)
Freeze code: 69303826
NET lock: 60261618
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 08-16-2017, 09:23   #18926 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung T679m Unlock done by read code
Operation: Read Codes
Selected model: SGH-T679M
Selected port: COM10 Z3X BOX Serial Port
Checking phone at COM10
Phone SN: R21C50CMVQ
PDA/CSC version: T679MUGKK1/T679MBMCKK1
Phone version: T679MUGKK1
Phone HW: REV0.1
Cal date: 2012.05.05
Reading IMEI... OK
IMEI: 35152105xxxxxxx
Reseting MSL... OK
Bypass MSL... OK
Reading codes... OK
Freeze code: 17472685
NET lock: 59316282
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Thanks z3x Team
Old 08-16-2017, 10:36   #18927 (permalink)
EjazATF's Avatar
Member: 2192499
Thanks Meter: 1,763
GT-S7582
Emergency Calls Only Solved via One Click
Operation: Repair
Selected model: GT-S7582
Model: GT-S7582
Android version: 4.2.2
Product code:
Phone version: S7582DDUAMK1
PDA version: S7582DDUANA1
CSC version: S7582ODDANA1
CSC sales code: INU
HW version: MP 0.101
Phone SN: R21F62M29MB
Modem board:
RF cal date: 20140613
IMEI: 3542180----------
Patching CERT check... OK
Repair done
Old 08-16-2017, 18:54   #18928 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 19
G920A Unlock Done.. Easyway
Operation: Unlock
Selected model: SM-G920A
Selected port: COM55 SAMSUNG Mobile USB Serial Port
Searching Samsung modem... detected COM54
Model: SM-G920A
AP version: G920AUCS6DQC1
CSC version: G920AATT6DQC1
CP version: G920AUCU6AQC1
Product code: SM2G920AZKAATT
Phone SN: RF8H10ZSAXX
Unique number: 1215FC1441E33304
Reading IMEI... OK
IMEI: 35180807015XXX (SIGN: OK)
Unlocking... OK
Unlock done
Old 08-17-2017, 16:30   #18929 (permalink)
Member: 2185549
Thanks Meter: 535
Operation: Unlock
Selected model: SGH-T139
Selected port: COM192 Z3X BOX Serial Port, 460800
Connect phone and press power button... Phone detected
Switching phone to TAT mode... OK
Phone version: T139UVJC1
IMEI: 01219500660049
Phone SN: RPUZ764218
Phone BT: D4:E8:B2:EB:4B:5A
Reading security... OK
Unlocking... OK
Unlock done
Old 08-17-2017, 16:39   #18930 (permalink)
Member: 1930570
Thanks Meter: 82
A310F FRP DONE
A310FXXU3BQC8_A310FOJV3BQC8
Model: SM-A310F
Product code: SM-A310FZKAXEU
Phone version: A310FXXU3BQC2
PDA version: A310FXXU3BQC2
CSC version: A310FXEU3BQC2
CSC country code: UK & IRE
CSC sales code: XEU
Phone SN: R28H436F6AW
Security patch: 2017-02-01
RF cal date: 20160427
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
BLACKSCREEN REV ERROR BINARY
SOLUTION
1 FIRST FLASH COMBINATION FULL COMBINATION_FAC_FA51_A310FXXU3AQC1
AND ENABLE USB DEBUGGING
DONT DO ANY FACTORY RESET JUST
PUT IT IN DOWNLAOD MODE AGAIN
2 FLASH THIS FIRMWARE A310FXXU3BQC2_A310FXEU3BQC2 GET IT FROM SAMFIRMWARE WHEN THE PHONE IS ON USB BUGGING IS ON
3: USE Z3X FOR FRP ADB
4: WHEN YOU ARE INSIDE THEN GO TO SETTING AND DO FACTORY RESET
PROFIT
IF THIS HELP YOU CLICK ON THANKS
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.42191 seconds with 10 queries
