10-14-2016, 15:21 | #16951 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G928A Software version: 26.9 Searching Samsung modem... detected COM153 Reading phone info... OK Model: SM-G928A AP version: G928AUCS2BPG1 CSC version: G928AATT2BPG1 CP version: G928AUCS2BPG1 Product code: SM2G928AZDEATT Phone SN: R38----- Unique number: 06157DF6DAE1DD28 Reading IMEI... OK IMEI: 3544---------- (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-14-2016, 22:48 | #16953 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | this also is done UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G900A Selected port: COM157 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 3535----------- Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 thanksss |
10-14-2016, 23:24 | #16954 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Reset FRP/React/EE Selected model: SM-N920P Software version: 26.9 Searching Samsung USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... OK Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.9 |
10-14-2016, 23:41 | #16955 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | SAMSUNG TAB I957 DONE UNLOCK INSTRUCTIONS: 1. Phone must be powered on. 2. Run 'Calculator' on phone and enter '+32286798378+' 3. Type *#1575# then press phone 'Menu' button and press 'Back'. 4. Choose Diag config to USB and return to dial. 5. Type *#7284# and choose USB to Modem. 6. Connect USB cable, install drivers if needed. 7. Select diagnostic port in port settings. 8. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SGH-I957 Selected port: COM161 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 0 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 THANKSS |
10-14-2016, 23:45 | #16956 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | LG G5 Your Device is Corrupt. It can't be trusted and may not work properly. AND hang on lg logo is done BY FLASHING WITH LG 2-3G Tool v9.26 Z3X BOX LG 2-3G Tool v9.26 supported models: 1388 Mode: Emergency Model: H850 Elapsed: 2 secs. --> (v9.26) Phone mode is DOWNLOAD Start flashing. Open KDZ File : C:\Users\jSmart\Desktop\H85010c_00_VDF_COM_OP_0415 .kdz Model : LG-H850 SwVersion : LGH850AT-00-V10c-OPT1-HQ-APR-15-2016+0 BuildTime : 0000-00-00 00:00:00 Total Files : 123 Model name: LG-H850 Software verion: H85010c Android verion: 6.0.1 IMEI: 357657------ Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. Start direct download mode Write "PrimaryGPT" partition #1 of 123 Write "laf" partition #2 of 123 Write "factory" partition #3 of 123 Skip "rct" partition #4 of 123 Write "persist" partition #5 of 123 Write "system" partition #6 of 123 Write "system" partition #7 of 123 Write "system" partition #8 of 123 Write "system" partition #9 of 123 Write "system" partition #10 of 123 Write "system" partition #11 of 123 Write "system" partition #12 of 123 Write "system" partition #13 of 123 Write "system" partition #14 of 123 Write "system" partition #15 of 123 Write "system" partition #16 of 123 Write "system" partition #17 of 123 Write "system" partition #18 of 123 Write "system" partition #19 of 123 Write "system" partition #20 of 123 Write "system" partition #21 of 123 Write "system" partition #22 of 123 Write "system" partition #23 of 123 Write "system" partition #24 of 123 Write "system" partition #25 of 123 Write "system" partition #26 of 123 Write "system" partition #27 of 123 Write "system" partition #28 of 123 Write "system" partition #29 of 123 Write "system" partition #30 of 123 Write "system" partition #31 of 123 Write "system" partition #32 of 123 Write "system" partition #33 of 123 Write "system" partition #34 of 123 Write "system" partition #35 of 123 Write "system" partition #36 of 123 Write "system" partition #37 of 123 Write "system" partition #38 of 123 Write "system" partition #39 of 123 Write "system" partition #40 of 123 Write "system" partition #41 of 123 Write "system" partition #42 of 123 Write "system" partition #43 of 123 Write "system" partition #44 of 123 Write "system" partition #45 of 123 Write "system" partition #46 of 123 Write "system" partition #47 of 123 Write "system" partition #48 of 123 Write "system" partition #49 of 123 Write "system" partition #50 of 123 Write "system" partition #51 of 123 Write "system" partition #52 of 123 Write "system" partition #53 of 123 Write "system" partition #54 of 123 Write "system" partition #55 of 123 Write "system" partition #56 of 123 Write "system" partition #57 of 123 Write "system" partition #58 of 123 Write "system" partition #59 of 123 Write "system" partition #60 of 123 Write "system" partition #61 of 123 Write "system" partition #62 of 123 Write "system" partition #63 of 123 Write "system" partition #64 of 123 Write "system" partition #65 of 123 Write "system" partition #66 of 123 Write "system" partition #67 of 123 Write "system" partition #68 of 123 Write "system" partition #69 of 123 Write "system" partition #70 of 123 Write "system" partition #71 of 123 Write "system" partition #72 of 123 Write "system" partition #73 of 123 Write "system" partition #74 of 123 Write "system" partition #75 of 123 Write "system" partition #76 of 123 Write "system" partition #77 of 123 Write "cust" partition #78 of 123 Write "BackupGPT" partition #79 of 123 Write "PrimaryGPT" partition #80 of 123 Write "xbl" partition #81 of 123 Write "xblbak" partition #82 of 123 Write "BackupGPT" partition #83 of 123 Write "PrimaryGPT" partition #84 of 123 Write "xbl2" partition #85 of 123 Write "xbl2bak" partition #86 of 123 Write "BackupGPT" partition #87 of 123 Write "PrimaryGPT" partition #88 of 123 Write "BackupGPT" partition #89 of 123 Write "PrimaryGPT" partition #90 of 123 Write "boot" partition #91 of 123 Write "recovery" partition #92 of 123 Write "recoverybak" partition #93 of 123 Write "tz" partition #94 of 123 Write "tzbak" partition #95 of 123 Write "aboot" partition #96 of 123 Write "abootbak" partition #97 of 123 Write "raw_resources" partition #98 of 123 Write "raw_resourcesbak" partition #99 of 123 Write "rpm" partition #100 of 123 Write "rpmbak" partition #101 of 123 Write "hyp" partition #102 of 123 Write "hypbak" partition #103 of 123 Write "pmic" partition #104 of 123 Write "pmicbak" partition #105 of 123 Write "devcfg" partition #106 of 123 Write "devcfgbak" partition #107 of 123 Write "modem" partition #108 of 123 Write "sec" partition #109 of 123 Write "keymaster" partition #110 of 123 Write "keymasterbak" partition #111 of 123 Write "cmnlib" partition #112 of 123 Write "cmnlibbak" partition #113 of 123 Write "cmnlib64" partition #114 of 123 Write "cmnlib64bak" partition #115 of 123 Write "apdp" partition #116 of 123 Write "msadp" partition #117 of 123 Write "BackupGPT" partition #118 of 123 Write "PrimaryGPT" partition #119 of 123 Write "BackupGPT" partition #120 of 123 Write "PrimaryGPT" partition #121 of 123 Write "BackupGPT" partition #122 of 123 Write "OP_T" partition #123 of 123 Erase "rct" partition Done. Elapsed: 467 secs. --> (v9.26) THANKSSS |
10-15-2016, 11:10 | #16958 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | G920f imei repair done Operation: Repair Selected model: SM-G920F Software version: 26.9 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Searching Samsung modem... detected COM25 Reading phone info... OK Model: SM-G920F AP version: G920FXXU4DPGW CSC version: G920FVDS4DPH1 CP version: G920FXXU4BPF1 Product code: SM-G920FZKAVIR Phone SN: RF8G90PM3ZW Unique number: Reading IMEI... OK IMEI: Reading data from phone... OK HWID: 48 F1 48 6F 0D 06 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.26.9 |
10-15-2016, 16:58 | #16959 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,708 | note5 imei repair+patch cert done Code: Searching Samsung modem... detected COM143 Reading phone info... OK Model: SM-N920C AP version: N920CXXU2AOJ5 CSC version: N920COJP2AOJ5 CP version: N920CXXU2AOJ3 Product code: SM-N920CZSAMID Phone SN: RF8G91NW7RR Unique number: 836F363252344F42 Reading IMEI... OK IMEI: 352560074851384 (SIGN: OK) Reading data from phone... OK HWID: 48 58 A2 76 77 06 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Repairing IMEI... OK Rebooting phone... OK Repair done Code: Waiting ADB device... OK Reading phone info... Model: SM-N920C Android version: 5.1.1 Product code: SM-N920CZSAMID Phone version: N920CXXU2AOJ3 PDA version: N920CXXU2AOJ5 CSC version: N920COJP2AOJ5 CSC country code: Iraq CSC sales code: MID HW version: MP 0.700 Phone SN: RF8G91NW7RR Modem board: SHANNON333 RF cal date: 20150917 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done |
10-15-2016, 17:46 | #16960 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N910T Selected port: COM103 SAMSUNG Mobile USB Serial Port Software version: 26.9 Checking CERT file... OK KEY ID: 0772 Waiting ADB device... OK Reading phone info... Model: SM-N910T Android version: 5.1.1 Product code: SM2N910TZKETMB Phone version: N910TUVU1COD6 modem PDA version: N910TUVU2DOK2 CSC version: N910TTMB2DOK2 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone SN: Rxxxxxxxxxxxxxxxx Modem board: MDM9225M RF cal date: 2015.05.23 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0772 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.26.9 |
10-15-2016, 17:53 | #16961 (permalink) |
Member: 2428732 Status: Offline Thanks Meter: 22 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Read QCN Selected model: SM-N910T Selected port: COM103 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading ID... OK Detected ID: 00000FF7 (MDM9x25) SW version: MPSS.DI.3.0.c5-00396-M9625TAARANSZM-2 Reading ESN... OK Backuping RFNV... OK Backuping FeatureMask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Reading QCN done Done with Samsung Tool PRO v.26.9 |
10-15-2016, 19:41 | #16962 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | UNLOCK DONE I317 UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-I317 Selected port: COM163 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 355428050193378 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-15-2016, 21:12 | #16963 (permalink) |
Member: 2428732 Status: Offline Thanks Meter: 22 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-I337 Selected port: COM110 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 356xxxxxxxxxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-15-2016, 21:26 | #16964 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | HELLO IS DONE SM-J500M UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J500M Selected port: COM164 SAMSUNG Mobile USB Serial Port Software version: 26.9 Reading phone info... Reading IMEI... OK IMEI: 35214------- Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.9 |
10-16-2016, 10:31 | #16965 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | sm-G530H hang solved Quote:
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
