06-02-2017, 08:16 | #18466 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | [ 6/2/2017 9:11:00 AM ] Selected model: SM-J100H [ 6/2/2017 9:11:00 AM ] Software version: 28.2 [ 6/2/2017 9:11:00 AM ] [ 6/2/2017 9:11:00 AM ] File analysis... Ok [ 6/2/2017 9:11:00 AM ] Total file size: 0x3D98398C (985 Mb) [ 6/2/2017 9:11:00 AM ] Searching USB Flash interface... COM16 detected [ 6/2/2017 9:11:00 AM ] Setup connection... Ok [ 6/2/2017 9:11:00 AM ] Set PIT file... Ok [ 6/2/2017 9:11:00 AM ] Reading PIT from phone... Ok [ 6/2/2017 9:11:00 AM ] Sending recovery.img... Ok [ 6/2/2017 9:11:00 AM ] Sending system.img... Ok [ 6/2/2017 9:12:00 AM ] Sending SPRDCP.img... Ok [ 6/2/2017 9:12:00 AM ] Sending SPRDDSP.img... Ok [ 6/2/2017 9:12:00 AM ] Sending nvitem.bin... Ok [ 6/2/2017 9:12:00 AM ] Sending cache.img... Ok [ 6/2/2017 9:12:00 AM ] Sending hidden.img... Ok [ 6/2/2017 9:12:00 AM ] Flashing done (time - 00:01:12) [ 6/2/2017 9:12:00 AM ] |
06-02-2017, 13:39 | #18467 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Samsung e1050 repair imei Selected model: E1050 Selected com port: COM102 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 7A Sending loader2... OK Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 48 second, sw ver: 3.5.0040 |
06-02-2017, 13:41 | #18468 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Repair imri samsung e1070 Selected model: E1070 Selected com port: COM103 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 7A Sending loader2... OK Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 47 second, sw ver: 3.5.0040 |
06-02-2017, 15:29 | #18469 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2528233 Status: Offline Thanks Meter: 20 | Samsung E1282T Phone Lock Read Codes Done by Z3X Box Operation: Read Codes Selected model: GT-E1282T Selected port: COM11 SciCmpst Diag Software version: 28.2 Reading phone info... Ok IMEI: 353576054xxxxxx IMEI 2: 353577054xxxxxx Product code: GT-E1282RWTAFG Phone HW: MP 0.500 Phone SN: RV1CB6GRDF Reading codes... Ok Please wait, calculating codes... OK (time - 00:00:14) Freeze code: 57417350 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to Aaadil Ansari For This Useful Post: |
06-03-2017, 08:59 | #18470 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Read Codes GT-S5610K Operation: Read Codes Selected model: GT-S5610K Selected port: COM5 ?Z3X BOX Serial Port Software version: 28.1 Connect phone and press power button Phone detected Switching phone to TAT mode... Ok Reading phone info... Ok Phone version: S5610KJVMJ1 IMEI: 35914704958551 Phone SN: RZ1F12FYN9 Phone BT: 34:31:11:5C:57F Reading security... Ok Please wait, calculating codes... Ok Freeze code: 49183460 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 00000000 Phone lock: 00000000 |
The Following User Says Thank You to orhan5 For This Useful Post: |
06-03-2017, 18:58 | #18472 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G550T Software version: 28.1 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: SM2G550TZKATMB Phone version: G550TUVU2AQC4 PDA version: G550TUVU2AQC4 CSC version: G550TTMB2AQC4 CSC country code: USA CSC sales code: TMB HW version: REV0.4 Phone SN: RV8HA0M5V8H Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 RF cal date: 20161019 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: F2 CA 1B E1 EE EA 2D FF 05 7D 08 11 5A FC FD E9 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
06-04-2017, 08:46 | #18473 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-G935F Software version: 28.2 Searching Samsung modem... detected COM337 Reading phone info... Ok Model: SM-G935F AP version: G935FXXU1DQBT CSC version: G935FVFG1DQBT CP version: G935FXXU1APG1 Product code: VOD Phone SN: R58HC12J1RW Unique number: AD0B1603A0355F8321 Reading IMEI... Ok IMEI: 354315088218072 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to wsmobile For This Useful Post: |
06-06-2017, 04:03 | #18475 (permalink) |
Freak Poster Join Date: Feb 2005 Location: At the Shop
Member: 120273 Status: Offline Thanks Meter: 57 | Sprint S7 G930P Android 7.0 = SUCCESSFUL UNLOCK! Operation: Unlock Selected model: SM-G930P Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-G930P Android version: 7.0 Product code: Not Active Phone version: G930PVPU4BQAA PDA version: G930PVPU4BQAA CSC version: G930PSPT4BQAA CSC country code: USA CSC sales code: SPR HW version: REV0.6 Phone SN: 00000000000 Modem board: MSM8996 Security patch: 2017-02-01 RF cal date: 2017.01.02 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
06-06-2017, 11:32 | #18476 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-G935F Software version: 28.2 Searching Samsung modem... detected COM379 Reading phone info... Ok Model: SM-G935F AP version: G935FXXU1DQB7 CSC version: G935FVFG1DQB7 CP version: G935FXXU1APG1 Product code: MOB Phone SN: RF8H617VV2M Unique number: CE051605B356CB1203 Reading IMEI... Ok IMEI: 352204082431315 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
06-06-2017, 12:28 | #18477 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Operation: Unlock Selected model: SM-G920W8 Software version: 28.2 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G920W8 Android version: 7.0 Product code: SM-G920WZKARWC Phone version: G920W8VLU5DQD4 PDA version: G920W8VLU5DQD4 CSC version: G920W8OYA5DQD4 CSC country code: Canada CSC sales code: RWC HW version: REV1.0 Phone SN: RF8G70TP2CR Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-04-01 RF cal date: 20150713 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Ok HWID: 48 70 CB 4E B6 04 00 00 00 00 00 00 00 00 00 00 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
06-06-2017, 12:53 | #18478 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G532F Frp Reset Code: Operation: Reset FRP Selected model: SM-G532F Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDPAK Phone version: G532FXXU1AQB3 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.300 Phone SN: R58J11VKL8P Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 RF cal date: 20170108 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
06-06-2017, 12:54 | #18479 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung G532F Frp Reset Code: Operation: Reset FRP Selected model: SM-G532F Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZSDPAK Phone version: G532FXXU1AQB3 PDA version: G532FXWU1AQB5 CSC version: G532FOJV1AQB5 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.300 Phone SN: R58HC2YM10L Chip name: MT6737T Modem board: MT6737T Security patch: 2017-03-01 RF cal date: 20161214 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 |
06-06-2017, 13:03 | #18480 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | G925P FRO RESET DONE Operation: Reset FRP/React/EE Selected model: SM-G925P Software version: 28.2 Searching Samsung USB Flash interface... COM38 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
