09-12-2017, 15:18 | #19081 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-J320H/DS Software version: 28.6 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J320H Android version: 5.1.1 Product code: SM-J320HZDDEGY Phone version: J320HXXU0APH1 PDA version: J320HXXU0AQC3 CSC version: J320HOJV0AQC3 CSC country code: Egypt CSC sales code: EGY HW version: MP 0.300 Phone SN: R51J7004BNE Modem board: SC7730SW Security patch: 2017-03-01 RF cal date: 20170701 IMEI: Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Repairing Slave IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.28.6 |
09-12-2017, 15:18 | #19082 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Patch Certificate Selected model: SM-J320H/DS Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-J320H Android version: 5.1.1 Product code: SM-J320HZDDEGY Phone version: J320HXXU0APH1 PDA version: J320HXXU0AQC3 CSC version: J320HOJV0AQC3 CSC country code: Egypt CSC sales code: EGY HW version: MP 0.300 Phone SN: R51J7004BNE Modem board: SC7730SW Security patch: 2017-03-01 RF cal date: 20170701 IMEI: Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.28.6 |
09-12-2017, 16:10 | #19083 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 29.2 SUCCESSFULLY REMOVE FRP AND SAMSUNG ACCOUNT(SAMSUNG SM-G615F)USB FLASH FILE : G615F COMBINATION.rar SELECT MODEL G610F Operation: Reset FRP Selected model: SM-G610F Software version: 29.2 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G615F Android version: 7.0 Product code: SM-G615FZKDINS Phone version: G615FXXU1AQDB PDA version: G615FXXU1AQF4 CSC version: G615FODD1AQF4 CSC country code: India CSC sales code: INS HW version: MP 0.200 Phone SN: XXXXXXXXX Chip name: MT6757 Modem board: MT6757 Security patch: 2017-06-01 RF cal date: 20170626 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 THANKS Z3X-BOX TEAM |
09-12-2017, 22:29 | #19084 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G925A Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G925A Android version: 6.0.1 Product code: SM-G925AZKAATT Phone version: G925AUCU6EQCF PDA version: G925AUCS6DQC1 CSC version: G925AATT6DQC1 CSC country code: USA CSC sales code: ATT HW version: REV0.2 Phone SN: R38G402PR4N Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-03-01 RF cal date: 20150404 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 1F 3A 74 37 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-13-2017, 10:56 | #19085 (permalink) |
Major Poster Join Date: Jan 2017 Location: Dhaka.BD
Member: 2667438 Status: Offline Sonork: 100.1676500 Thanks Meter: 34 | Samsung SM-J111F Unlock done easily in z3x Operation: Read Codes Selected model: SM-J111F Software version: 29.2 Searching Samsung modem... detected COM65 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2 Product code: SM-J111FXXXXXX Phone SN: RV8J60GZDSH IMEI: 35765XXXXXXXXXX Unique number: C8G010B4B1CB144 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:17) Freeze code: 82716059 NET lock: 16283075 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 |
09-13-2017, 21:47 | #19086 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G935P Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G935P Android version: 7.0 Product code: Not Active Phone version: G935PVPU4BQH1 PDA version: G935PVPU4BQH1 CSC version: G935PSPT4BQH1 CSC country code: USA CSC sales code: SPR HW version: REV0.7 Phone SN: 00000000000 Modem board: MSM8996 Security patch: 2017-08-01 RF cal date: 2016.10.21 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
09-14-2017, 01:16 | #19087 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | G955F unlock done Operation: Unlock Selected model: SM-G955F Software version: 29.0 Searching Samsung modem... detected COM66 Reading phone info... OK Model: SM-G955F AP version: G955FXXU1AQG5 CSC version: G955FVFJ1AQFE CP version: G955FXXU1AQG5 Product code: VFJ Phone SN: R58J56YNDCD Unique number: CE05171528D83C510D Reading IMEI... OK IMEI: 3591220xxxxxxxx Reading SN... OK Phone SN: R58J56YNDC Enter MSL: 34305C2126440C480B02600441531846 Bypass MSL... OK Unlocking... OK Codes set to 00000000 Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
09-15-2017, 09:22 | #19088 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Samsung Tool PRO 29.2 SUCCESSFULLY REMOVE FRP (SAMSUNG SM-A510F)USB FLASH FILE : COMBINATION_FAC_FA51_A510FXXU4AQC1_FAC_CL9213193_Q B12832200_REV00_user_mid_noship.rar Operation: Flash Selected model: SM-A510F Software version: 29.2 File analysis... OK Total file size: 0x04CD9CF8 (76 Mb) Searching USB Flash interface... COM36 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending persdata.img... OK Sending modem.bin... OK Sending cache.img... OK Flashing done (time - 00:00:13) Done with Samsung Tool PRO v.29.2 ################################################## ################################################## #### Operation: Reset FRP Selected model: SM-A510F Software version: 29.2 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM-A510FZWFINS Phone version: A510FXXU4AQC2 PDA version: A510FXXS4BQC3 CSC version: A510FDODD3BQA4 CSC country code: India CSC sales code: INS HW version: MP 0.00 Phone SN: XXXXXXXXXX Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20160813 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 THANKS Z3X-BOX TEAM |
09-15-2017, 10:44 | #19089 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | j320h ds frp lock done -select model j200h ds Operation: Reset FRP/React/EE Selected model: SM-J200H/DS Software version: 29.2 Searching Samsung USB Flash interface... COM14 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
09-16-2017, 03:03 | #19090 (permalink) |
Junior Member Join Date: Oct 2016 Location: Libya
Member: 2641167 Status: Offline Thanks Meter: 0 | Waiting ADB device... OK Reading phone info... Model: SM-G925L Android version: 6.0.1 Product code: Phone version: G925LKLU3DPL1 PDA version: G925LKLU3DQA1 CSC version: CSC country code: CSC sales code: HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 G925l (lgu+) korean version repair imei by z3x job done>> the device came to me with no drk >> custum recovery + root + finally repair imei with samsung tool pro thanx z3x team for good job Last edited by mtc8407; 09-16-2017 at 03:08. Reason: MISSING TEXT |
09-16-2017, 12:04 | #19091 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-G531F Software version: 29.1 Checking CERT file... OK KEY ID: 0001 Waiting ADB device... OK Reading phone info... Model: SM-G531F Android version: 5.1.1 Product code: SM-G531FZWAXSG Phone version: G531FXXU1APB2 PDA version: G531FXXU1APC2 CSC version: G531FOJV1APC1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.200 Phone SN: R58G926CCXM Modem board: Security patch: 2016-03-01 RF cal date: 20150924 IMEI: Checking Super user right... true Reading NV data... OK Analyzing SEC file... OK Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0001 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.29.1 |
09-16-2017, 14:09 | #19092 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | J1 ace FRP done(SM-J111F) Code: Waiting ADB device... OK Reading phone info... Model: SM-J111F Android version: 5.1.1 Product code: SM-J111FZWDTHR Phone version: J111FXXU0APD2 PDA version: J111FXXU0APD4 CSC version: J111FOJV0APD4 CSC country code: IRAN CSC sales code: THR HW version: MP 0.200 Phone SN: *********** Chip name: SC9830I Modem board: SC9830i Security patch: 2016-05-01 RF cal date: 2016.08.06 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 |
09-16-2017, 14:27 | #19093 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | s4 L720 unlock done Code: Operation: Unlock Selected model: SPH-L720 Selected port: COM3 Z3X BOX Serial Port Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SPH-L720 Android version: 4.4.2 Product code: Not Active Phone version: L720VPUFNG2 PDA version: L720VPUFNG2 CSC version: L720SPTFNG2 CSC country code: USA CSC sales code: XAS HW version: Phone SN: 00000000000 Modem board: MDM9615M RF cal date: NONE IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-16-2017, 15:57 | #19094 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | SM-G920F android 7.0 Patch Certificate done Operation: Patch Certificate Selected model: SM-G920F Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 Product code: SM-G920FZDAXEF Phone version: G920FXXU5EQH7 PDA version: G920FXXU5EQH7 CSC version: G920FOXA5EQH7 CSC country code: France CSC sales code: XEF HW version: MP 1.00V Phone SN: RF8H52LX64M Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-08-01 RF cal date: 20160525 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 |
09-16-2017, 19:31 | #19095 (permalink) |
No Life Poster Join Date: May 2010 Location: FLAT EARTH
Member: 1295624 Status: Offline Thanks Meter: 152 | Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1AQB6 PDA version: J327PVPU1AQB6 CSC version: J327PSPT1AQB6 CSC country code: USA CSC sales code: BST HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 RF cal date: 2017.05.16 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... false Super user right required true Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.9 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
