08-19-2018, 21:54 | #20911 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Venezuela Age: 33
Member: 1916710 Status: Offline Thanks Meter: 288 | J700m Flash Done Selected model: SM-J700M Software version: 33.5 File analysis... OK Total file size: 0x741A2030 (1857 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending cache.img... OK Sending cm.bin... OK Sending hidden.img... OK Sending modem.bin... OK Sending recovery.img... OK Sending sboot.bin... OK Sending system.img... OK Flashing done (time - 00:02:01) Done with Samsung Tool PRO v.33.5 |
08-19-2018, 21:54 | #20912 (permalink) |
Member: 1916710 Status: Offline Thanks Meter: 288 | Frp J700M Operation: Reset FRP/React/EE Selected model: SM-J700M Software version: 33.5 Searching Samsung USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.5 |
08-19-2018, 22:26 | #20913 (permalink) |
Member: 1916710 Status: Offline Thanks Meter: 288 | Operation: Repair Selected model: SM-J700M Software version: 33.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J700M Android version: 6.0.1 PDA version: J700MUBU2BRA1 CSC version: J700MUUB2BRA2 Phone version: J700MUBU2BQK1 Product code: SM-J700MZWAARO CSC country code: Argentina CSC sales code: ARO Phone SN: R58Jxxxxxxx IMEI: 86985xxxxxxxxxx HW version: MP 0.700 RF cal date: 20170116 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-08-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.33.5 Operation: Patch Certificate Selected model: SM-J700M Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-J700M Android version: 6.0.1 PDA version: J700MUBU2BRA1 CSC version: J700MUUB2BRA2 Phone version: J700MUBU2BQK1 Product code: SM-J700MZWAARO CSC country code: Argentina CSC sales code: ARO Phone SN: R58xxxxxxxx IMEI: 86985xxxxxxxxxx HW version: MP 0.700 RF cal date: 20170116 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-08-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.5 |
08-20-2018, 14:38 | #20915 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | a510f 7.0 unlocked UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-A510F Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 7.0 PDA version: A510FXXU5CRF1 CSC version: A510FMBM5CRF2 Phone version: A510FXXU5CRF2 Product code: SM-A510FZKAMBM CSC country code: MACEDONIA CSC sales code: MBM Phone SN: RF8H41DES2R IMEI: 3581700xxxxxx66 HW version: MP 0.200 RF cal date: 20160414 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 2D D1 90 12 4E 24 41 8E C4 6A 90 24 54 0A 8A A2 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.5 |
08-20-2018, 14:50 | #20916 (permalink) |
No Life Poster Join Date: Nov 2006 Location: algeria
Member: 395094 Status: Offline Thanks Meter: 58 | Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 PDA version: J330FNXXU2AQK8 CSC version: J330FNXEF2AQK2 Phone version: J330FNXXU2AQK8 Product code: SM-J330FZKNXEF CSC country code: France CSC sales code: XEF Phone SN: R58K42BCLPB IMEI: 355730097990058 HW version: MP 0.500 RF cal date: 20180413 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-12-01 Boot Warranty bit: 0 Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 50318251 NET lock: 17042939 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
08-20-2018, 15:28 | #20917 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Read Codes Selected model: SM-G532M Software version: 33.5 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532M Android version: 6.0.1 PDA version: G532MUMU1APK4 CSC version: G532MUWA1APK3 Phone version: G532MUBU1APK4 Product code: SM-G532MZDACDR CSC country code: Dominican Republic CSC sales code: CDR Phone SN: R58J35VK1JB IMEI: 357485089446688 HW version: MP 0.300 RF cal date: 20170327 Chip name: MT6737T Modem board: MT6737T Security patch: 2016-11-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM18 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:22) Freeze code: 15703596 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 31629252 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
08-20-2018, 17:37 | #20919 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Operation: Unlock Selected model: SM-G550T Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G550T Android version: 6.0.1 PDA version: G550TUVU2AQC4 CSC version: G550TTMB2AQC4 Phone version: G550TUVU2AQC4 Product code: SM2G550TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: RV8HA0AJD1J IMEI: 353764081747739 HW version: REV0.4 RF cal date: 20161012 Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: EC 82 79 0B 3A 36 8C 07 A3 49 59 39 A0 DA E5 A2 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.5 |
08-20-2018, 20:45 | #20920 (permalink) |
Member: 1916710 Status: Offline Thanks Meter: 288 | Read Codes GT-S5360L Operation: Read Codes Selected model: GT-S5360L Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: GT-S5360L Android version: 2.3.6 PDA version: S5360LUHLB1 CSC version: S5360LPETLB1 Phone version: S5360LUHLB1 Product code: GT-S5360MAKPET CSC country code: PERU CSC sales code: PET Phone SN: IMEI: 354664052939100 HW version: MP 0.700 RF cal date: 20121012 Chip name: Modem board: Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:19) Freeze/Master code: 00406020 NET lock: 80604040 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
08-20-2018, 22:20 | #20921 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | UNLOCK Operation: Read Codes Selected model: SM-N920A Software version: 33.5 Searching Samsung modem... detected COM31 Reading phone info... Model: SM-N920A AP version: N920AUCS5ERF2 CSC version: N920AATT5ERF2 CP version: N920AUCU5ARA1 Product code: ATT Phone SN: RF8H30R4C7N IMEI: 000000000000000 Unique number: 05157DF5D82F1A11 Reading IMEI... OK IMEI: 356714075225710 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON333 HWID: 68 CC CD 0E 35 04 00 00 00 00 00 00 00 00 00 00 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:14) Freeze code: 57380469 NET lock: 20971407 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
08-20-2018, 22:58 | #20922 (permalink) | |
Insane Poster Join Date: Apr 2017 Location: Anaheim California
Member: 2710649 Status: Offline Thanks Meter: 47 | N950U Bit5 ATT Unlock success Quote:
08-20-2018, 23:52 | #20923 (permalink) |
Crazy Poster Join Date: Apr 2016
Member: 2553878 Status: Offline Sonork: [email protected] Thanks Meter: 16 | voici la solution de déblocage de samsung j327P avec z3x 1_ write COMBINATION_SPT_FA60_J327PVPU3AQJ1 2_flash avec ce bin telecharger sur le serveur z3x J327PVPU3AQJ3_SPT3AQJ3 3_ lire le code SPC/msl 4_taper le code ##3424# sur le paver numerique et saisi le code spl/msl 5_et 1 clic sur qualquom et choisi option dm+acm+adb et ok 6_wrte le ficher NV J327P Skynet Team avce le programme NV Items Reader and Writer le tour est jouer unlock ok.. |
08-21-2018, 05:22 | #20924 (permalink) |
Freak Poster Join Date: May 2011 Location: battambong, cambodia
Member: 1582587 Status: Offline Sonork: 100.1654576 Thanks Meter: 20 | SM-A530F A8 2018 Unlock [Done] log Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A530F Android version: 7.1.1 PDA version: A530FXXU1AQL2 CSC version: A530FOXM1AQL2 Phone version: A530FXXU1AQL2 Product code: SM-A530FZKDXEF CSC country code: France CSC sales code: XEF Phone SN: R58JC39CXXXX IMEI: 35215809XXXXXXX HW version: REV0.3 RF cal date: 20171221 Chip name: EXYNOS7885 Modem board: SHANNON327 Security patch: 2017-12-01 Boot Warranty bit: 0 Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 84207352 NET lock: 16135190 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
The Following User Says Thank You to svaysokhom For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
